Indicator Trouble - NEED HELP!
Postby Gripper Rob » Mon May 20, 2013 10:44 pm
Hi, in need of help!
Basically my alarm stopped recognising my fob whilst miles away from home, so called AA who came out and gained access to my van and disoconnected my alarm as he thought the alarm was knackered ...but now the rear passenger indicator doesnt work(yes, even with a new bulb) and also when I put the hazards on it causes my brake light to flash rather than the indicator. This has got me baffled and would really appreciate any advice on what the problem might be and any possible remedies to this problem! Thanks, Rob.
Gripper Rob
Re: Indicator Trouble - NEED HELP!
Postby loot » Tue May 21, 2013 7:39 am
is it the Ford fob or an after market alarm?
have you checked the basics like the contacts where the harness connects to the bulb holder?
07 350 170ps
Ids map here
loot
Postby Gripper Rob » Tue May 21, 2013 8:34 am
It is a Laser Line alarm ...I did quickly check the contacts as I had a bad earth which I have managed to sort but still have this problem. I will thoroughly check all the contacts again and see if this helps.
Gripper Rob
Postby limitedblack » Tue May 21, 2013 4:27 pm
Are you 100 percent sure it worked before they disconnected the alarm, just sounds like dodgy earth issues.
Happy Easter
limitedblack
Postby bortaf » Thu May 23, 2013 2:01 am
limitedblack wrote:Are you 100 percent sure it worked before they disconnected the alarm, just sounds like dodgy earth issues.
This /\ or corrosion across the plug contacts ? alarms dont usually tap into the brake lights only sidelights or indicators :?:
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
