2.4 duratec, rwd, lwb, 07 altenator problem
Postby tomo320 » Tue May 21, 2013 11:29 am
Hello,
Could anyone help me get the altenator belt off please, there has been a long power steering fluid leak and the altenator is full of fluid and the batteries are draining.
I can see the tensioner with a 13 mil nut is there any other nuts that need releasing to let the tension off the belt?
When all is back together again will it tension back up on it's own?
Many thanks,
Paul.
tomo320
Re: 2.4 duratec, rwd, lwb, 07 altenator problem
Postby karl » Tue May 21, 2013 11:32 am
At the back off the tensioner their is a square hole a 3/8 ratchet fits in perfect that's how it's done the bolt is to take the wheel off
If you have a feel around the back of it you will find it it's on fan side
It a self tensioner as well so when you putting back you might need another pair off hand to put the belt over the tensioner as so one has the tensioner UN tensioner it that makes sense
karl
Tranny Lover!!!
Postby blue estate » Tue May 21, 2013 1:10 pm
karl mcghee wrote:At the back off the tensioner their is a square hole a 3/8 ratchet fits in perfect that's how it's done the bolt is to take the wheel off
3/8 ? Don't you mean 1/2 inch
blue estate
Postby karl » Tue May 21, 2013 1:58 pm
its one off them :lol:
karl
Tranny Lover!!!
Postby angeleye » Tue May 21, 2013 2:05 pm
http://www.ebay.co.uk/itm/BRAND-NEW-TEN ... 2ec72ad21a
click the link it shows a picture of tentioner and you can see the square hole where you put socket bar in just release tention by pushing bar anti clockwise
take a note of where belt feeds rounds pulleys before you take belt off
angeleye
Postby tomo320 » Wed May 22, 2013 9:23 am
Thanks a lot, was a 0.5 inch recess, should have seen the beggar!
Cheers again,
Paul.
tomo320
cron
