2008 2.4 running fault
Postby westyr1 » Wed May 22, 2013 8:03 pm
Hi
I have a 2008 transit 2.4 with a strange fault. It can drive fine for 2 or 3 weeks but then it faults and will barly run.
While it is faulting the milage left display is flashing like mad,it may tick over ok sometimes but as soon as you give it any throttle it misfires badly and the display flashes madly! On reading the codes with a delphi scanner the fault present at the time is an injector leak. i have not carried out a leak off test yet assuming that a faulty injector would not cause these dash problems.
Does any one have any leaders where to look, i am thinking chaffed wiring?
westyr1
Re: 2008 2.4 running fault
Postby apples26 » Sun May 26, 2013 2:54 pm
My mates does this every few months or so if he's on a long run throttled off to a stop and it misses farts around once hits 2500 rpm it's smooth. Drops it off for look next day it's fine lol
http://WWW.NEEDATOW.CO.UK
apples26
Postby ake » Sun May 26, 2013 5:07 pm
Get both batteries checked.
Postby westyr1 » Mon May 27, 2013 4:55 pm
I will do that first thing in the morning thanks
westyr1
Postby busmanjda » Fri May 31, 2013 6:24 pm
have a 2008 115 . does the same thing but a milder form , just when it feels like. had a diagnostic ( no fault ). changed the egr valve , was clear for about 6 month, they reckon you need to change the egr valve every 50000 mile .
busmanjda
Postby apples26 » Fri Jun 07, 2013 3:18 pm
mates one went down again today exact same symptoms, its had 4 new injectors new prv pump learn etc etc, a sensor on the pump done, every few thousand miles it just f*** up with the same symptons this is the 5th time its happened
it had two new batteries and new injectors the first time it went wrong
its back down m&b fuels sometimes just better leaving it to the more knowledgable
apples26
Postby taz666 » Fri Jun 07, 2013 4:09 pm
this is becoming a common fault on mk7s, the loom that comes from the pcm runs across the top of the n/s headlight and then drops down the side of the underbonnet fusebox and is secured to a metal plate by a plastic clip, follow the loom down and it go into a "U" loop that goes up into the engine, at that loop weve had water ingress problems into the loom and rotting wires, pull the loom up and take the plastic corrogated covering off and inspect the wires around the loop in the wiring and i bet there are green wires, the ones weve had rot are most commonly for the injectors causing running problems and dash displays to flash, done one a couple of weeks ago with the same problems :wink:
taz666
Ford Technician
Postby apples26 » Fri Jun 07, 2013 4:25 pm
Interesting cheers, is it from the top or underside for inspection
apples26
Postby apples26 » Fri Jun 07, 2013 6:40 pm
Looks like Neil found the issue, as he had it running poorly upon wriggling ecu plug it ran perfect, loose pin!
Oh and he also on the occasion when the problem occurred had a weirdly behaving display
apples26
Postby loot » Sat Jun 08, 2013 9:47 am
I find these to be the worst jobs lol I had a pin came right out on a connector behind the dash which gave me problems with the fan etc :x
07 350 170ps
Ids map here
loot
Postby taz666 » Mon Jun 10, 2013 6:42 pm
apples26 wrote:Interesting cheers, is it from the top or underside for inspection
from the top :D
taz666
Ford Technician
Users browsing this forum: Majestic-12 [Bot], metalworker0, Sports140
