Rob Cee's transit - start of makeover
Re: Rob Cee's transit - start of makeover
Postby robbie.cee » Fri May 17, 2013 12:00 am
Ok so i just ordered a fuse holder and 2 60A link bars, and to be safe a 200a relay as it was only a few quid more than a pony 70a one that had SPADE terminals...
this one has two large bolts and nuts protruding from bottom so it'll be a more secure fixing !
will eventually find the thick cable i got its either in shed of dread or van locker ...
got a few spare switches so ill just need some spare time and ill be laughing, well tinkering!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Tue May 21, 2013 11:41 pm
:evil: hoping the second pump the guy sends actually works ... finally had a play with it and nada, not even a spark.
to be fair the guy did say he'll send another straight away, and not to bother posting back...
on the up side i actually fitted that replacement exhaust stud :lol:
only about 9 days til we move house..... :shock: gonna be soooo busy til then, prob wont get to play in van til moved. :(
least ill have me own car park tho :P
Had
MAKE IT FIT
robbie.cee
Postby mobilevanman » Wed May 22, 2013 1:13 pm
Rob you know to shout if you need help
why not if u dont someone will
mobilevanman
Postby robbie.cee » Wed May 22, 2013 5:37 pm
Nice one m8.... gonna need any spare bods on the 1st june if all goes to plan.
so anyone reading this thats able to, help would be most appreciated !!
Had
MAKE IT FIT
robbie.cee
Postby madbri » Wed May 22, 2013 6:06 pm
il help rob :wink: il take all ure tele and jewls in my van :mrgreen: :mrgreen: :lol:
madbri
Postby robbie.cee » Wed May 22, 2013 8:54 pm
jewels lol.... you can bring some of that ply down then lol
just fitted new door handle on sld, got it real cheap off ebay as i couldnt open sld from outside.
managed to slip a long 10mm socket in behind the card only removing 4 clips in top right corner!
result...
just leaves seatbelts windows carpet and bass bin/storage box n move friggin bulkhead forward again :lol:
then metal n respray then new exhaust system! :D
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Thu May 23, 2013 8:58 pm
Holy sh1t just found out move date is now 31st may, next friday (as of post date) :|
so Ron , Tony etc, if your still able to help out, it''ll be on the friday not the sat as previously advised by our estate twat agent!!!
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
so much to do... :|
i best get cracking......!
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Thu May 23, 2013 9:04 pm
On another note, will be collecting hopefully a working pas pump from the parcel place tomo, true to his word the guy sent another!!
Any one here confirm what my neighbour honestly believes ... pug/shitroen pas pump - 2 wires... one red one black ergo + and - .....
my mate reckons the motor has some sort of timer built in... i honestly seriously doubt it. think it was a duff pump hence it didnt work. will try holding power on for longer tomo but i was expecting a big ish spark and a motor spinning sound and associated twist of casing as torque happens...
i guess ioll find out tomo
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sun May 26, 2013 7:52 pm
well got pump but too busy to test so far...
sooo much crap in loft :oops:
now its all over place in our little house!!!
cant wait til fri now just want to get it over with!
then i can play transits 8) 8)
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Mon May 27, 2013 6:55 pm
OH HAPPY DAYS :P
the replacement pas pump, not only sparks on contact, but twists too and squirts!!!
just need to get over to burnt mills to the hydraulic place and get a "saxo pump to transit rack hp feed pipe" made up. theres a great perch for the pump to be fitted on. possibly with some hench U bolts perhaps, there s even 4 holes in roughly the right place... touch! :D
next pix should be in new garden....... :D :D :D
Had
MAKE IT FIT
robbie.cee
Postby hornhead » Mon May 27, 2013 7:12 pm
8) Best of luck with D day...
hornhead
Postby robbie.cee » Mon May 27, 2013 8:18 pm
hornhead wrote:8) Best of luck with D day...
Cheers Bud, im totally dreading it... :( BUT have got some help and it will be worth it!!!
PLUS A NEW PLACE FOR ESSEX MEETS 8)
Had
MAKE IT FIT
robbie.cee
Postby RonTransitmk5 » Wed May 29, 2013 11:16 pm
Well excited about the move m8.
Bus all emtied for you, emma & the lil one, m8.
just a couple of moving blankets in there & 2 ratchets, & 3/4 bungees.
Do you need any of my gardening equipment?
2003 Ford Transit Connect 1.8 TDDI Red.
1999 V reg MK5 Bus(M2) Mid Roof, 2.5di, diamond white. GONE
RonTransitmk5
0
Postby RonTransitmk5 » Wed May 29, 2013 11:24 pm
0
RonTransitmk5
Re: 0
Postby RonTransitmk5 » Wed May 29, 2013 11:31 pm
RonTransitmk5 wrote:0
dont know how to delete? the above mistake.
Anyone, instructions?
Please? going bed now as got 2 days off, 1 for diy round the house & 1 for robbies move.
RonTransitmk5
cron
