tipp3r wrote:I've cut the plugs of 2010 loom for clocks the couler of the wires don't match old loom
paul2012 wrote:As my connect originally had front fog lights, the headlight switch that came with the 2010 dash was not equipped for them.
So I obtained replacement from a C-Max, which works perfectly![]()
After receiving a few PM's on "how to stop the front bumper sagging in the middle & distorting bottom of top grille ?"
I advise to replace the lower bumper reinforcement bar (The thin bar that is mounted to the bottom of slam panel between headlights shown in pic below)
Part required Ford Part no F4992893 - This is the part where top of bumper clips onto just below the grille![]()
When fitted, bumper & bottom of top grille should look like this![]()
millertime_1985 wrote:looking over more of this thread I have to wonder, just how handy do you have to be to be able to do this sort of thing...
not that I have any grand designs like this for my own TC... but I can't imagine its physically/practically easy doing such a drastic facelift to your TC
especially since I doubt they sell an instruction manual.
PeterBuzzacott wrote:Nice work mate and thanks for posting in such detail. Your van has come up a treat.
paul2012 wrote:Bagged this for a fiver - chap didn't know what it was![]()
Removed from a 2012 connect, I was supprised to see it was virtually stripped. it had only been in for a couple of days
Yaw rate sensor complete with mounting bracket - The final part for the ESP & hill start assist![]()
These cost over £400 new from Ford![]()
Although still waiting for the ABS pump to arrive
by the end of your project, how much of your van will remain the same as when it was shipped out of turkey...
and.. how much do you reckon you will have Saved, over just buying an "09" model TC?
paul2012 wrote:
Alot cheaper than a good used low mileage 2009 onwards basic model
