Luke's 24v cosworth into mk1/2 thread!!!
Postby Guy88 » Mon Jan 22, 2007 9:50 pm
Mine looks like that but not as neat :oops: :oops: :lol:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
s/s exhausts
Postby dipstick » Mon Jan 22, 2007 11:05 pm
Luke,
wow, that sounds like a task ....... :) i like the ply template though ....
let us know how you get on..... how do you bend the s/s tube....?
good luck, cheers :)
dipstick
Cosworth Powered
Cosworth Powered
Re: s/s exhausts
Postby Luke » Mon Jan 22, 2007 11:11 pm
dipstick wrote:how do you bend the s/s tube....?
you can get them in 90deg elbows and weld together 8)
i'll put pics up as im doing it :D
hmmmm
Postby dipstick » Mon Jan 22, 2007 11:15 pm
Luke,
you are getting me thinking now ....did you order the s/s over t'interweb? if so, have you a URL....? how do intend to form the ovalised header ends?..... i can see a way of me saving a large wad of cash here ... :twisted:
cheers...... :D
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Mon Jan 22, 2007 11:19 pm
no i didnt get it over the net i got it locally im in the engineering trade- to ovalise the ends - just squash them - depending on what you have press or vice they may need heat too :D
if you want to discuss this further lets start another thread as i want to keep this one about my conversion and ill post up pics as i go :D
Postby Sundowner » Tue Jan 23, 2007 8:57 am
Luke wrote: to ovalise the ends - just squash them - depending on what you have press or vice they may need heat too :D
or cut the pipe through the center spread it and fill the "V" with some flat plate
Yeah i know its big green and rusty so move your Porsche before i bash it with 460 cubes of fords finest cast iron
Sundowner
Postby Guy88 » Tue Jan 23, 2007 6:32 pm
Luke wrote:no i didnt get it over the net i got it locally im in the engineering trade- to ovalise the ends - just squash them - depending on what you have press or vice they may need heat too :D
Is it seamless :?:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Fri Jan 26, 2007 12:05 am
Guy88 wrote:Is it seamless :?:
dont think so - i dont think its made that way :!:
anyway started on the stainless flanges got so far all done on a pillar drill, with a hole saw - yep 'a' hole saw :lol: was on its last legs after the last hole but it did its job :lol:
just gotta grind them oval some how :roll: and cut each one out :x
the idea with the 4 pilot holes is incase i need to reposition the studs i can - i'll only drill out the ones i need :idea:
just go to do the same again for my n/a manifold now :)
Postby gemini » Fri Jan 26, 2007 12:20 am
Luke wrote:just gotta grind them oval some how :roll:
easy
gemini
Postby Guy88 » Fri Jan 26, 2007 7:21 pm
When i made the adaptors for mine. i used seamed and when it was squashed the seams cracked :(
Looking well thou 8)
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Fri Jan 26, 2007 8:04 pm
well today i cut the bit left between the holes and spent about half an hour with the die grinder and got 1 done :lol: its 6mm thick it looks thinner in the pic :D
still waiting for the elbows and tee's but im in no rush it will be a while before ive got the flanges ready :lol:
oh and did i mention i got the fan off the engine :x :lol: so im gonna look at mounting the rad this weekend :D
Postby Luke » Sat Jan 27, 2007 7:26 pm
Radiator fitting :D
i must admit from reading the other threads on the 24v conversions - i think ive got the easyest MK to do it on :D - basically i started trying to fit a DOHC sierra rad with the electric fans, it wouldn't fit in so i cut out the 2 rad supports and the centre bracing off the front panel, then it went in, i had to fit all the belt and pas pump etc. back on, once i did i saw it was too low so i raised it up about 6" and it was ok :D
i then thought i wonder if i can use the granadas rad -as its slightly bigger :idea: also has the added bonus of the temp sensor in it, so i took the cowling off the sierra one and if fitted straight on the granny one 8) that now sits about 4" off the cross member and will locate into the slam panel once ive modded it to acept the mounting holes :D all i will have to do is make 2 brackets for the btm mounts and it looks pritty good - very tight but fits :lol:
Postby Luke » Tue Jan 30, 2007 10:53 pm
i didnt post any progress after sunday but i basically spent all day fitting and un fitting the rad to make sure it was 100% if i hadnt done this i would have ended up with the bonnet striker hitting it :oops:
this is the pic of the bottom mounts - they pick up on the front bumper mounts and the granada rad sits on them, as you can see the rad isnt perfectly central this is to do with the offset on the fans - i'll aslo need 2 top mounts but i havent made them yet :D
my plan is to get it running without the fan cowl on, then fit the fans last, as the cowl may need slight modification - its very close :?
Postby rover » Tue Jan 30, 2007 11:57 pm
The rad in that pic defo aint central mate, looks like its fitted on the wall in the house to me :lol: :lol:
But seriously, top marks for the engineering mate....if it dont fit...make it fit :D
Rover.
rover
Postby Luke » Sat Feb 03, 2007 6:21 pm
no pics but ive got the rad fitted in place today - mounts needed a bit of modding so they both look like the one on the left now :lol: i even fitted the hoses too 8) i'm not sure on the header tank position - i did save a mk4 transit one but i cant find it - i dont want to go drilling holes then find its no good :x its all very close on the o/s with the servo being in the way too :(
also im gonna have a go at wiring in the trip/fuel computer as it doesnt need much wiring - so ive been told - the biggest problem is i need a feed from the sender so - fingers crossed tomorrow im gonna take the tank out of the granada and make a frame and fit it in the back of the van - just to get it running then possably make a tank in the origanal position with a fitting for the granada pump/sender :? :idea: just ideas at the moment :lol:
also my stainless elbows turned up today for making my turbo manifolds - just need a couple of turbos now :P
