engine running signal
Postby andrew_fraser2001 » Thu Sep 15, 2005 10:12 am
Hi Folks,
I have taken a "GPS tracking system" out my old van and fitted it into my new transit.
I am looking for a 12 volt signal when the engine is running. Can anyone tell me where i can find that? . I have a new transit 350. TD . I would rather not take a feed from the alternator, ford say i will invalidate the warranty!
appreciate any ideas,
Andy
andrew_fraser2001
Postby FredTransit » Thu Sep 15, 2005 10:15 am
Welcome Andy! Can't help you with newer vans, but I am sure somebody here will. The tracker sounds interesting, did you fit it yourself to your old van, or did it come with it?
FredTransit
Mk2 Trannyist
Postby andrew_fraser2001 » Thu Sep 15, 2005 10:32 am
Hi ,
Thanks for your response,
Yea I fitted the tracker to my old van. and now have it in my transit, but i would like a signal or voltage that tells me when the engine is running. The reason is the tracking system i have can log engine running hours.
Andy
andrew_fraser2001
Postby FredTransit » Thu Sep 15, 2005 10:38 am
Where did you get it from? Other people might be interested too.
FredTransit
Mk2 Trannyist
Postby Luke » Thu Sep 15, 2005 10:43 am
Welcome andrew!! :D
MrMpuk (mike) has the wiring drawings on cd! he may be able to help you!!! (he will be along shortly :lol: )
If you were to take it off the altenator will the signal be a constant 12v?
Can you not take it off the live feed from the key? would that be good enough?
:D
Postby andrew_fraser2001 » Thu Sep 15, 2005 10:57 am
I cant remember the company i bought it from, but i think its called a "trackm8"and the system it is on is called "pinpointers" http://www.pinpointers.com, I can just log on view all sorts of info about my van, also cuts my insurance. it also has a "trembler" in it,
basicly if someone brakes into my van, my van will send me a text message...it does all sorts of things
had it about 3 years now. Handy tool especialy if like me your van is your
livleyhood
Andy
andrew_fraser2001
Postby andrew_fraser2001 » Thu Sep 15, 2005 11:19 am
It just needs to be between 6v and 30v when the engine is running and 0 volts when the ign key is off. I dont want voltage on the first click of the ignition barrel or the second click , only when engine is running.
It's not that important but when i start to look for something is consumes me :lol:
Seemingly the alternator is a No No. Warranty and stuff!
Andy
andrew_fraser2001
Postby Luke » Thu Sep 15, 2005 1:04 pm
andrew_fraser2001 wrote:It just needs to be between 6v and 30v when the engine is running and 0 volts when the ign key is off. I dont want voltage on the first click of the ignition barrel or the second click , only when engine is running.
Andy
ah i see, only when the engine is running, hmmm, does the rev counter get a +v feed???
Like i say mike has the drawings, so i'll wait for him!! :lol:
12v feed
Postby john leeman » Thu Sep 15, 2005 1:23 pm
on most ford wiring looms the solid yellow wire is radio etc behind the unit which is easy to get to thats on when the key is in position 1 & 2, I would go for that, but check warranty ?.
35 years of driving,repairing,sleeping in transit's lovin every minute.
john leeman
Postby FredTransit » Thu Sep 15, 2005 1:32 pm
andrew_fraser2001 wrote:I cant remember the company i bought it from, but i think its called a "trackm8"and the system it is on is called "pinpointers" http://www.pinpointers.com, I can just log on view all sorts of info about my van, also cuts my insurance. it also has a "trembler" in it,
livleyhood
Andy
Can I ask how much it cost?
FredTransit
Mk2 Trannyist
Postby WINDSCREENGUY » Thu Sep 15, 2005 1:59 pm
is it me or is that link not working
formally grey van man.
WINDSCREENGUY
previously grey van man
Postby FredTransit » Thu Sep 15, 2005 2:01 pm
Not just you GVM, I can't get through to the link either. Can ya do it again Andy?
FredTransit
Mk2 Trannyist
Postby nediam » Thu Sep 15, 2005 3:32 pm
Link not working due to the comma at the end.
Try http://www.pinpointers.com/content/
nediam
Postby MrMPuk » Thu Sep 15, 2005 4:08 pm
Just a quick question Andrew before I start looking through the wiring diagram, why can't it be switched from the ignition, it seems quite odd to only have it on when the engine is on! How many wires does the unit have, and what do they all do?
Postby MrMPuk » Thu Sep 15, 2005 4:11 pm
Okay so I've just read the title, you want an engine run signal I guess so it knows when the engine is running. No probs I shall have a look.
