How to fit a 2nd row of seats?
Postby nediam » Thu Sep 15, 2005 9:42 am
Cheers for all the replies :)
Seems like it's a grey area so I'll check with my local MOT garage and give the "authorities" a bell.
Thanks for the offer Johnnyshag. I'm gonna look at a few vans this weekend, so I'll let you know if I can use them :D
nediam
Postby FredTransit » Thu Sep 15, 2005 9:55 am
I think you should pay attention to the post MrMPUK did. He copied it from the ROSPA site, and some testers are not up to date with later regs. After all I was told by our tester that lap belts were not acceptable. If you fit seats with seat belts, and they want to fail you, either appeal or take em out and get the test without them. it's unlikely you will get pulled by the police for seats, and if the worse comes to the worse you will only have to get a re test, again go without them. That's what I would do (theoretically :wink: )
FredTransit
Mk2 Trannyist
Postby madmark » Thu Sep 15, 2005 11:21 am
the best way is look out for a 3 seater transit minibus seat from around a 95 onwards ,these have belts already in ,and you can use the load eye from the floor near the side door for the belt holder! but good luck drilling the holes thru the floor 12 if i remember ! :D
Postby Luke » Thu Sep 15, 2005 12:53 pm
I have a 3 set from a smiley to go in mine! (no belts yet :( )
i am making a frame using metro runners so i can slide the seats all the way forward when i need the loadspace and have no passangers- im useing metro runners cos there very flat!! :D
And i'll just need 6 bolts through the floor - but i'll weld a strengning piece on the each contact area!!
:D
Postby Gunslinger » Sun Sep 25, 2005 4:26 pm
just seen these on ebay ....
any good to you ? you'll have to be quick it finishes Ends 26-Sep-05 11:42:07 BST :(
http://cgi.ebay.co.uk/Ford-Transit-Minibus-Folding-Bench-Van-Seat-Belts_W0QQitemZ4576765137QQcategoryZ108855QQrdZ1QQcmdZViewItem
Gunslinger
Postby nediam » Tue Sep 27, 2005 9:20 am
Oops! only just seen your reply (didn't go online yesterday as I was van hunting)
They look good :) and seem to be in good nick. I'll have to "keep 'em peeld" in future! :D
Thanks for the reply though.
nediam
Postby Gunslinger » Tue Sep 27, 2005 11:12 am
no probs, i will keep my eyes open, if i find anymore i'll post them in here .. :shock: wow those went to £112, that i didnt expect
Gunslinger
Postby FredTransit » Tue Sep 27, 2005 11:36 am
Gunslinger wrote:no probs, i will keep my eyes open, if i find anymore i'll post them in here .. :shock: wow those went to £112, that i didnt expect
£112 isn't actually a bad price. Folding seats are very expensive, and 2nd hand fixed oned go for about £50 per seat (so £150 for a triple) in my local yards.
FredTransit
Mk2 Trannyist
Postby Gunslinger » Tue Sep 27, 2005 2:16 pm
hahahaha ..... screw that, freeloaders in the back of my van get the door handle on the inside to hold onto .... or they walk :P ... £112 blah, not worth it, its not like i'm ever going to sit on them :lol:
Gunslinger
seatbelt laws
Postby vanmania » Tue Sep 27, 2005 6:32 pm
ive done this sort of work many times nediam make sure you weld it ok
if it is poss go to a scrappy look for a minibus near age to yours and if u can take which ever seat u using there footings, Dont forget u might have to take it to the minestery to be checked, last one i did for a mate he had to take it there, it passed u get a certificate i think it cost about £50, the m.o.t. r getting so mean :lol: 8) :wink:
vanmania
Postby Sundowner » Sun Jan 15, 2006 7:01 am
Im fitting a second row seat to my MK2 van its actually a bucket/bench type Had to fab up a 150mm high frame for it to sit on and to also house the PS2 amps, compressor inverter and tools
Also fitting retractable belts, this is a must and needs to be engineered
the body needs to be braced where the belts/seat mount too
I will post pics soon
Yeah i know its big green and rusty so move your Porsche before i bash it with 460 cubes of fords finest cast iron
Sundowner
Postby frank_sumner » Sun Jan 15, 2006 8:47 pm
Go To Feedback & Supplier Listings. I got two 3 seaters from Ford Parts UK for £49.99 each (brand new!!). They also have some with belts fitted, but these are more expensive.
frank_sumner
Postby rallyevo3 » Sun Jan 15, 2006 9:40 pm
I got a double and a single seat off Ebay for £15 the lot... all with 3 point belts.... bargain or what?
When I looked at the bottom of the frames they had a clip affair made by Unwins so they could be slotted in and out... I bought the matching runner from Unwins for £40 delivered and hey presto I can have 1, 2 or 3 seats in various positions.. luvly jubbly :D :D
This is the rail
http://www.unwin-safety.com/frames/frameset.htm
Versatility & Strength
This is the part that bolts to the frame
Camlock is unique in that it incorporates a floating lower section which is more tolerant of slight inaccuracies in rail laying and seat manufacture. The cam action, when operated, makes the whole structure rigid, locking securely in the rail so as not to rattle, and forming a very strong fixing.
It is suitable for both single seat and double seat applications.
Secured to the seat with a simple cap head screw and washer it is suitable for 280mm, 305mm, and 330mm seat leg centres.
Product Code-Camlock- LSF/CAM/M1/S
Ian
rallyevo3
Postby sidspop » Mon Jan 16, 2006 10:36 am
I can't believe that all you seem to be bothered about is the MOT! How about the lives of whoever is in the back, and you as well.
10 stone of child travelling at 60mph into the back of your head will hurt.
Sod the MOT, sod the cost, get belts fitted.
If you're gonna do the job, do it right.
Andy
sidspop
Location: The Black Country (near to Brummagem, but not the same)
Postby FredTransit » Mon Jan 16, 2006 11:19 pm
sidspop wrote:I can't believe that all you seem to be bothered about is the MOT! How about the lives of whoever is in the back, and you as well.
Andy
Don't hit anything? It was good enough advice in the 80s........... :shock:
FredTransit
Mk2 Trannyist
