What did you do to your connect today?
Re: What did you do to your connect today?
Postby liteace » Thu Jun 20, 2013 12:46 am
NC53 wrote:Paul, can I ask what you did with the abs sensor - presumably you just unplug it from where it goes into the stub axle but won't that leave a hole?
cheers
PS - hoping to do this conversion on my 07 Connect this weekend which does not have abs. I've got the whole axle assembly from a 2011 model.
The sensors are bolted in, what i done with mine was take them out, chop of the sensor wire as close as poss to the sensor then bolt the sensors back in
Please don't send me PM's, i can't access them, when I try I get this:
You are not authorised to send private messages
liteace
Postby NC53 » Fri Jun 21, 2013 10:51 am
Thanks. Wasn't sure if people were removing them completely or just cutting off the wire.
NC53
Postby ucmanster » Sat Jun 22, 2013 10:33 pm
There i had some rust Look at left above corner!
so I coated with rust remover.
rust remover. first it is white and when it is dry , formed dark blue layer
brushed some rusty spots
protect area which will not be coated
ucmanster
Postby ucmanster » Sat Jun 22, 2013 10:49 pm
then coat with spray based on rubber and zinc
layer by layer
Then sprayed with colourless lacquer to protect previous coat
voula
next spring I will report how it went through winter :)
PS: Do you have this problem with rust too? My is 2006 and everywhere can find some rusty spots.
ucmanster
Postby Mylee » Mon Jun 24, 2013 8:26 pm
Refitted my alloys after a few months. And some new colourcoded front arches. 8)
Mylee
Postby deps-online » Mon Jun 24, 2013 9:29 pm
Van looking fookin sweet mylee what colour is that ihe arches
2005 T200L Connect 1.8 TDDI 75ps SWB with 45K on the clock
EGR Blank
Focus Air Box Mod (in the post)
JVC KD-R711
Edge ED205 3 Way Door Speakers
deps-online
Postby deps-online » Mon Jun 24, 2013 10:56 pm
Before Image
AfterImage
Was quite pleased with the results
EGR Blank
JVC KD-R711
deps-online
Postby Mylee » Mon Jun 24, 2013 11:31 pm
deps-online wrote:Van looking fookin sweet mylee what colour is that ihe arches
Ford Polaris Grey
Mylee
Postby liteace » Tue Jun 25, 2013 2:23 pm
Mylee wrote:Refitted my alloys after a few months. And some new colourcoded front arches. 8)
Just my personal preference, that has for to be one of the smartest looking vans Ive seen, the Mk2 or facelift or what every you call it, front bumper for me is the best, 1st model (like I have) and last model, I dont like the front ends
With the Alloys, color coded parts & headlamps its looks bang-on, not to overdone
liteace
Postby Chazzer » Wed Jul 03, 2013 9:22 pm
Took the van down to vantuner to have a postal remap tweaked, and will be adding a boost controller and gauge for more power :twisted:
Martin is an excellent guy, and really knows his stuff, well pleased with the service, definitely recommend his services to anyone wanting more power!
Charlie
If your not living on the edge, your taking up too much room...
Chazzer
Postby jimfish38 » Wed Jul 03, 2013 9:32 pm
where is Martin based ?
jimfish38
Postby Mylee » Wed Jul 03, 2013 10:09 pm
jimfish38 wrote:where is Martin based ?
Uxbridge
Mylee
Postby gt_addict » Wed Jul 03, 2013 10:40 pm
Chazzer wrote:Took the van down to vantuner to have a postal remap tweaked, and will be adding a boost controller and gauge for more power :twisted:
Charlie
Let us know how you get on with the boost controller, what type, what pressure etc as I'm still toying with the idea of it on mine since I've had the remap over a year I'm getting itchy fingers for more power.
I tried one of the ball a spring type ones and the van didn't react too well. It spat its dummy out even when it was on the lowest setting.
gt_addict
Postby millertime_1985 » Sun Jul 07, 2013 9:03 pm
finally got round to removing the wheel arch trim (NSF) and the NSF inner wheel arch liner...
although I ended up rounding a couple of the screws, and had to drill one of them out... got lucky with the other one...
so I think a trip to Ford beckons for tomorrow so I can fit the new arch liner and arch trim... and then I can fit the new deflector.
just need to figure out what clips and which screws I need from Ford... so that's the mornings activities set.
Its Not a Van..... Its a Transit
millertime_1985
Postby paul2012 » Mon Jul 08, 2013 12:49 am
millertime_1985 wrote:finally got round to removing the wheel arch trim (NSF) and the NSF inner wheel arch liner...
Metal clips (P slip), 2 types available Ford Part No F4748992 or F6846716
Screws Ford Part No F1250514
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
