Mist washer jets
Mist washer jets
Postby gt_addict » Tue Jun 25, 2013 7:57 am
Hi guys,
I bought a set of mist washer jets (genuine ford ones) from eBay and fitted them to my connect. My only problem is that they seem to fire at the windscreen a bit low down. Did ford make different mist washers at different angles? Or do another manufacturers mist jets fit fords?
Cheers,
Peter.
gt_addict
Re: Mist washer jets
Postby wisiiri » Tue Jun 25, 2013 8:41 am
take a needle. but it to hole where water cames. you can turn it whwere you want i to point. it is ball shape nozzle. sorry, bad english :|
wisiiri
Postby gt_addict » Tue Jun 25, 2013 10:32 am
Unfortunately these have no adjustment on them. They are the mist type ones NOT the jet ones that have two streams of water on each nozzle.
They mist just above the wipers but I'd like it a bit further up to be honest. Anyone have any suggestions?
gt_addict
Postby Adam_84 » Tue Jun 25, 2013 9:53 pm
Depending how tight they fit in can you not get something that's wedge shaped to push underneath it to raise the front a tad without leaving any gaps. Some pictures would help especially as I'd like to fit some too :-)
Adam_84
Postby g-man » Tue Jun 25, 2013 10:00 pm
never heard of em :!:
g-man
Postby gt_addict » Wed Jun 26, 2013 7:28 am
They are fitted to the new various new ford models from 2012 as far as I know.
eBay number for a heated pair ( I went for non-heated )
https://www.ebay.co.uk/itm/170785425276
Ill see it I can get a small 1mm packer from work and wedge it under there. They still hit the screen but just not as high as I'd like :/
gt_addict
Postby Parcel » Wed Jun 26, 2013 8:18 am
Are you sure they don't adjust a bit?
The ones on my Civic can be adjusted by a small amount. The whole nozzle bit moves in the housing using a small screwdriver in a slot. Can't believe that Ford can build a car so accurately that the jets squirt right every time
Parcel
Postby wisiiri » Wed Jun 26, 2013 8:20 am
wisiiri
Postby gt_addict » Wed Jun 26, 2013 8:52 am
Thanks wisiiri.
Ill give it a go with a screwdriver later after work, but as the thread wisiiri posted up they aren't adjustable, apparently.
Dot of glue ill try as well.
gt_addict
Postby Adam_84 » Wed Jun 26, 2013 8:49 pm
Those heated jets are expensive lol
Adam_84
Postby gt_addict » Wed Jun 26, 2013 9:34 pm
Yep :) luckily I haven't got to worry about such luxuries as a heated screen :lol:
gt_addict
Postby Adam_84 » Fri Jun 28, 2013 2:45 pm
Unfortunately I do though lol think we need a video of how well they work once you get them spraying right.
Adam_84
Postby Jamysumm » Fri Jun 28, 2013 2:54 pm
I've been looking for these since I got a ford , once I had them on my vw I loved them
Jamysumm
Postby ATL-driver » Fri Jun 28, 2013 3:07 pm
i have these on my mk1.5 focus, when the mk3 focus came out i paid £2.60 for heated mist jets from main dealer, BUT now the price is many times that....
ATL-driver
