MR16 in GU10 Spotlight?
Postby suffolkboi » Tue Jun 25, 2013 12:06 am
Has anyone used the GU10 to MR16 convertors from Amazon/Ebay etc which allows use of 12v led in a modern spotlight fixture?
Does this make the bulb stick out too far?
Or has anyone a suggestion for wall mounted spotlights? Im struggling to find fixture that take a MR16 bulb..
Mk5 Camper build - Work in progress
viewtopic.php?f=58&t=104595
suffolkboi
Re: MR16 in GU10 Spotlight?
Postby suffolkboi » Tue Jun 25, 2013 11:36 pm
So no one is running these LED bulbs in a spotlght that isn't recessed..? :?
suffolkboi
Postby suffolkboi » Tue Jun 25, 2013 11:39 pm
suffolkboi
Postby Brains_transit » Wed Jun 26, 2013 12:14 am
Why not use the gu10 led bulbs
Brains_transit
Postby deps-online » Wed Jun 26, 2013 12:34 am
Hi mate think I can help as im a sparky and deals with these problems most days but normally in buildings lol....what is it actly your wantibg to do
2005 T200L Connect 1.8 TDDI 75ps SWB with 45K on the clock
EGR Blank
Focus Air Box Mod (in the post)
JVC KD-R711
Edge ED205 3 Way Door Speakers
deps-online
Postby limitedblack » Wed Jun 26, 2013 6:40 am
The aftermarket LED bulbs are never as good as a purpose built led lamp, True led down lighters are really bright now, but they need to be kept cool, so one big heat sink unit, about £30 but last 20 years. The GU10 adapters have to lose both the drop down voltage and the led heat, so are never as good. Depends how much light you want, it won't match a GU 10.
Happy Easter
limitedblack
Postby Northwest2go » Wed Jun 26, 2013 6:55 am
LED's emit hardly any heat at all compared to a GU10 halogen.
06 MK6 camper conversion, Mercedes C180,
98 Alfa spider ph2 2.0 TS, 2000 alfa spider & 99 alfa GTV V6 3.0.
Northwest2go
Postby limitedblack » Wed Jun 26, 2013 8:11 am
Northwest2go wrote:LED's emit hardly any heat at all compared to a GU10 halogen.
It's not the heat emitted, it's the fact that the led has to be kept relatively cold. To get really good output on an led it has to be run hard near the limit, and this needs a big heat sink, and even a fan if its at maximum. Hence if your stuck on space the lamp won't be it's brightest.
Happy Easter
limitedblack
Postby suffolkboi » Wed Jun 26, 2013 10:43 am
I can't find any GU10 12v bulbs. Thats the problem.
Why do you say they wont be good enough? Ive got some similar to these
http://www.ebay.co.uk/itm/MR16-GU5-3-Wh ... 43b05ba1e3
I don't see why they wont be any good. I just want a lamp to put them in, instead of having bare bulbs.
suffolkboi
Postby limitedblack » Wed Jun 26, 2013 5:39 pm
As stated, depends how much light you want. Have you got a load of spare bulbs that your trying to find a fitting for? Thread is a little confusing.
Happy Easter
limitedblack
Postby Northwest2go » Wed Jun 26, 2013 7:35 pm
suffolkboi wrote:I can't find any GU10 12v bulbs. Thats the problem.
You won't find GU10 12v lamps as they don't exist. 12V are GU5.3
Northwest2go
Postby suffolkboi » Wed Jun 26, 2013 11:13 pm
I know Gu10 12v don't exist. And as far as i know GU5.3 are essential an MR16.
Don't see what all the confusion is - I have some MR16 LED bulbs, but cant find any lamp/directional spotlight to put them in (Other than flush fitting spot lights)
So i was just asking if anyone had come across some..
suffolkboi
Postby Northwest2go » Thu Jun 27, 2013 7:00 am
Aaaaahhh, I'm with it now. (sorry) I work in Electrical wholesale and (bulbs) in the trade are always referred to as lamps. When I first started in Electrical wholesale, I spoke about bulbs, I was immediately put righ by my boss who said "They're lamps! Bulbs you put in the garden!
Anyway. All our directional spot fittings are GU10 and we don't have LV's as there is no call for them in the domestic trade.
However, It's not that they don't exist...I'll have a look in some catalogues at work to try and find some for you that may suit.
Northwest2go
Postby ake » Thu Jun 27, 2013 7:19 am
You do get MR16 LEDs but they are more expensive than the mains fed GU10 variant, which are more common.
I take you know that the lamp holders are different and that you will need to change it to suit the MR16 lamps?
Look on ebay, plenty choice on there
Postby limitedblack » Thu Jun 27, 2013 5:43 pm
I think he just asked a simple question that someone on eBay makes an adaptor to take the 230v down to 12, what do we think of them. Short answer we don't know. I wouldn't bother trying to adapt a gu10 fitting to put cheap led bulbs (Americans still refer to them as), in.
Just spend the right amount of money and buy a proper led unit, that will be it for 20 years. Chances are the adaptor will fail before the bulb or fitting, so waste of money.
Happy Easter
limitedblack
cron
