MK6 SWB Cosworth YB Conversion!
Re: MK6 SWB Cosworth YB Conversion!
Postby madbri » Mon Jun 18, 2012 8:12 pm
just a thought :roll: is it not easyer changing the diameter of ure tyre just to play 1st?
madbri
Postby MinorMatt » Mon Jun 18, 2012 8:20 pm
Its not that hard to change an axle... and tyres are expensive (especially for someone from Yorkshire! :lol: )
Postby Luke » Mon Jun 18, 2012 8:27 pm
:lol: tyres wont last long on this :lol: its not so much getting of the line with this it seemed to loose so much more time on a gear change :? and it certanly wont set off in 2nd - tried it - no good at all :!:
Postby Luke » Fri Jul 27, 2012 10:24 pm
We've fitted an uprated fuel pump on this tonight - it was a walbro 244 (same one ive got on my van) :D 1st test drive was very promising 8) but we still have problems with setting the boost level - next step stu is going to take the van and have it set up on a rolling road 8)
Postby Luke » Sat Oct 06, 2012 8:00 pm
Luke wrote:next step stu is going to take the van and have it set up on a rolling road 8)
well 3 months later............... took it this morning to noble motorsport
unfortunately £80 later they couldn't sort it :( but they confirmed fuel pressure is OK but its rich on tick over and lean on boost :?
they suspect a wiring fault we've put the origanal ecu back on and it does run better - i'd like to try another stage 3??? ecu on it as i'm not convinced the one we have is any good :|
Postby Luke » Sun Oct 14, 2012 8:14 pm
we've now had it running for a while on the standard ecu and its ok :) tried the chipped chip in it and it's no good :( i think the problem is the chipped chip&ecu are for a 2wd and this is a 4wd :idea:
we now want a 4wd chip to fit in the origanal ecu, cross our fingers and hope its sorted 8)
Postby captain hook » Sun Oct 14, 2012 11:42 pm
Over 4 and half years and still not right!
This must be a forum record...... :lol: :lol:
captain hook
Postby conrod » Mon Oct 22, 2012 9:30 am
Luke wrote:we've now had it running for a while on the standard ecu and its ok :) tried the chipped chip in it and it's no good :( i think the problem is the chipped chip&ecu are for a 2wd and this is a 4wd :idea:
make sure the TPS is correct one for the ECU, 2WD one (red from memory) is different to 4WD one (black) I think the 5V and 0V wires are around the other way. What wiring loom are you running? (2WD or 4WD?) 2WD chip not interchangable into 4WD ECU, and vice versa. What numbers are on the ECU?
conrod
Postby Luke » Tue Oct 23, 2012 9:25 pm
i think this is the problem the ecu and chip are off a 2wd and the origanal ecu is a 4x4 we've tried the chip in the origanal 4x4 ecu but as you say it wont work.
the wiring loom is a 4x4
we are going to try a 4x4chip in the origanal 4x4 ecu - but the other option is to just swap the tps for a 2wd one but i dont know if it will all swap with the wiring being a 4x4 loom :?
Postby conrod » Wed Oct 24, 2012 6:40 am
Hi Luke, 4x4 loom will work fine for either ECU. If you have 4x4 TPS (black PF09) then it will work fine, nothing to change, and will run on either ECU (4x4 or 2wd) If you have 2WD TPS (red PF01) then you need to swap outer two wires on TPS connector, as they are wired in reverse. This will also work for either 4x4 or 2WD ECU. Hope that makes sense? :D Also check the colour of the map sensor, should be black if you are running standard chip. And injectors should be dark blue for 4x4 engine, or yellow for 2wd engine (they are the same flow rate as each other) If you have any other colour injectors (or a grey map sensor) then chip needs to match these. Do not try to fit a 2wd chip into a 4x4 ECU ,and vice versa. You will probably damage the chip, and possibly the ECU. For a good "stage one" upgrade chip speak to Graham Goode Racing or Mountune. HTH.
Conrad
conrod
Postby Luke » Wed Apr 17, 2013 9:16 pm
found the fault with this today :D it was the crank sensor :!: :!: :!: - now runs spot on with the origanal ecu - this weekend we are going to try the uprated ecu and injectors :D
north weald here we come :lol:
Postby Luke » Sun Jun 30, 2013 9:21 pm
bit more work on this ready for north weald 2013 8)
my contribution welding up the old lpg cap :D
while martin paints it :D
i'll not say what the final colour scheme stu's got planned he's changed his mind enough times :lol: but if he can get it done in time it'll be fully stickered up for north weald 8) 8)
Postby AlanN » Sun Jun 30, 2013 9:43 pm
Great to hear its running smoothly, records to break :wink:
Postby Luke » Sat Jul 06, 2013 11:51 pm
taking shape 8)
can you guess what it is yet :lol:
Postby AlanN » Sun Jul 07, 2013 10:49 am
With a week to go, will it be in full livery Luke? Looks good as is, so far 8)
Im off to work in a little while to cut my broken screen out... :? Then I'll see how bad the rust is :!:
