Rob Cee's transit - start of makeover
Re: Rob Cee's transit - start of makeover
Postby robbie.cee » Sat Jun 29, 2013 11:01 pm
price of a pipe being made up !
any idea of address or name?
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Mon Jul 01, 2013 10:25 pm
So all this messing under bonnet got me itching to finish things I started a while ago...
Hope to get clutch sorted soon ,now got a new thrust bearing Friggin 40 quid from frauds...
And anyone got the name of the hydraulic place in burnt mills pls?
Ta
Had
MAKE IT FIT
robbie.cee
Postby captain hook » Mon Jul 01, 2013 10:35 pm
GSL, Harvey Road.....01268 590248
Advance, Repton Ct....01268 284097
Google is your friend you lazy ****** :lol:
captain hook
Postby jonochap » Tue Jul 02, 2013 12:34 am
Aw mate, comin on well :)
jonochap
Postby robbie.cee » Fri Jul 05, 2013 8:53 pm
Cheers capn. Using this phone for internet is as painful as the rest of the Friggin phone!
Laptops not usable at present on acct of wee me going nuts if he sees anything that lights up or plugs in...
Dunno where he gets that from....
:oops:
Will endeavor to get round to one ASAP. Any previous dealings with either of em ?
On a plus note, modified clutch fork with blowlamp and removed failed bush on the counter weight thingy...
Now welded on for a few hdmi leads by a coach works in orpington I never knew existed!
Soon to be refitted by Mvn ASAP!
Had
MAKE IT FIT
robbie.cee
Postby mobilevanman » Sat Jul 06, 2013 10:21 am
Looking at wed or thurs mate u will go to the ball oopppps wrong fairy tale lol
why not if u dont someone will
mobilevanman
Postby robbie.cee » Sun Jul 07, 2013 9:20 am
Nice one mate!
Had
MAKE IT FIT
robbie.cee
Postby RonTransitmk5 » Mon Jul 08, 2013 12:06 am
The stuff your doing on your motor is way over my head m8 :-)
Looking forward to North Weald. :D :D :D
2003 Ford Transit Connect 1.8 TDDI Red.
1999 V reg MK5 Bus(M2) Mid Roof, 2.5di, diamond white. GONE
RonTransitmk5
Postby robbie.cee » Mon Jul 08, 2013 8:07 pm
Same ere dude
Just got Aaron some baby ear defenders !
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Wed Jul 10, 2013 10:55 pm
So it became apparent that the release bearing was fooked... one complete race of balls in the bell housing :shock:
still its seen 3 engines and one helluva life so it deserves a rest!
Managed to persuade the defective bush in the clutch fork/arm, the bit of rubber that sleeves the arm into the weighty bit cable attaches to ...
fire and big hammer got the bits apart...lots of fire needed mind! i used my rothenberger blowlamp...
got the end welded back on...for 4 hdmi leads, result ( had to virtually force him to take em, didnt want owt for doing it and i never met him before!)
hopefully gettinh fitted fri , else im fkd for north weald!!!
ps A MK3 ARM WONT FIT LATE TYPE MK5 CLUTCH, ARM TOO SHORT, PULLS OFF OF DOME, DONT BOTHER, WELD IT BACK UP!! :wink:
and heres wee me with mates fully automatic, authentic weighted 6mm airsoft machine gun... friggin thing is awesome but you'd get shot dead if seen in public with it, lucky i got a firing range now... :P Fires 6mm paintballs too 8) 8) 8)
and before anyone rings childline... i didnt actually let him have a go...yet!
Had
MAKE IT FIT
robbie.cee
Postby captain hook » Wed Jul 10, 2013 11:13 pm
Rob....As much as don't like pi55ing on your bonfire....
I don't see any grind marks where he's cleaned the weld area and...
I don't see much penetration to the welds :?
captain hook
Postby robbie.cee » Wed Jul 10, 2013 11:27 pm
my welder didnt even mark the metal m8. seems sound. i bashed the fek out of it , held up so far.... will find out soon, else ill be buying an arc welder :lol:
i would have preferred he weld every possible area but as it was done as a favour i thought better of asking. the pix aint the best there is actually penetration , but not to the point where you usually get a 'run' or 'drip'. think also cos the head is so dense it needed more energy to get it molten, and my lil baby mig only does 130A...
and i couldnt find the gas ive since found!
do you still have any seat belts going Cap'n? ill be getting shore leave some point soon... :shock:
Had
MAKE IT FIT
robbie.cee
Postby captain hook » Wed Jul 10, 2013 11:45 pm
Welded without gas :shock: :shock: :shock:
Rob.......You're asking for trouble :roll:
Bring it over and my 180 amp Mig will pour some in 8) 8)
captain hook
Postby robbie.cee » Thu Jul 11, 2013 12:01 am
captain hook wrote:Welded without gas :shock: :shock: :shock:
the guy who did it for me used gas, dont fret, he had a lincoln, like yours. are you about tomo, guess approx 1130 ish? can scoot it over before i leave for work as got morning off completely for Aarons annual health check up/review.
cheers Cap'n
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sun Jul 14, 2013 6:16 pm
Well good news is the clutch fork held up. Sadly the plate finally relieved its centre spline of its duty and seperated.
That meant mvm hastily get box off again.
Doh
New plate arrives
Fitted
Bite not possible.
Gear box back out at 5pm
Old clutch cover back on
Box back on last few bolts in 630
Leave Essex sharpish
Get to north weald bout half 7.
Epic
Then it turns out my bolts keep working loose
So starter half handing out one bolt sheared,
And to top it off the dizzy half jumped out of hole again
Friggin Thing.
Drive home (til I hit Basildon) was better running than up strip.
Gutted missed dizzy loose til too late!
Will get there eventually, will do under 20 next time I hope
Off for a much needed soak!
Had
MAKE IT FIT
robbie.cee
