Rust, How bad is this?
Re: Rust, How bad is this?
Postby xychix » Tue Jul 16, 2013 8:17 am
stalwart wrote:Did this van fail the MOT on needing welding?
Nope not yet, I didn't want to wait for that.
It would likely fail on Dutch MOT (APK) for the rust, however if it fails I need to show the weld without finishing it off.
If I weld it on forehand I can apply underbody paint over all of it and there's no extra inspection on the welding.
xychix
Postby stalwart » Tue Jul 16, 2013 6:30 pm
Thats fine no problem,may i suggest you work some seam sealer all along the edges,before you underseal it and grind down those spot welds flush,be nice to see the finish and see if it goes through the MOT :wink:
stalwart
Postby xychix » Wed Jul 17, 2013 8:36 am
stalwart wrote:Thats fine no problem,may i suggest you work some seam sealer all along the edges,before you underseal it and grind down those spot welds flush,be nice to see the finish and see if it goes through the MOT :wink:
seam sealer (that is what i called welding kit i assume, sticky white stuf to close off the edges) will be applied.
Last picture is with grinded down spot welds. At the moment a layer inox spray sits on top of it as it's awayting seam sealer / owatrol en underseal.
xychix
Postby stalwart » Wed Jul 17, 2013 9:14 am
You'll want a Polyurethane sealer something like this
http://www.toolstation.com/shop/Adhesiv ... 350/p67949
Its what i use good stuff too :wink: ,dont know if you can get it in holland though
stalwart
Postby xychix » Wed Jul 17, 2013 11:07 am
http://www.valvolineeurope.com/english/ ... ory=tectyl
this is what I have for underseal. (1 spraycan)
and this
for the inside of the hollow spaces (also 1 can)
additionally I tend to put owatrol oil in / on everything as it is awersome! It even works it's way UP on the metal!
xychix
Postby xychix » Tue Aug 27, 2013 9:09 pm
yes, got trough dutch MOT (APK) today with my new welded patches and exhaust.
:D :D :D :D
xychix
Postby davey0555 » Tue Aug 27, 2013 9:30 pm
Congratulations on gaining your new MOT!, I have just welded the exact same place on my van !!
1989 MkIII Transit camper
davey0555
