Led Strip Lights Under Shelving...
Postby Mikee » Mon Jul 22, 2013 9:32 pm
Hi Guys/Gals,
I'm going to be fitting out my Mk7 with some wooden shelving soon and was just wondering how difficult would it be to connect up 12v LED strip lighting on the underside of the shelves and have them connected to the rear courtesy light circuit? I'm rubbish with current draws etc so not sure if this is feasible. Anybody with auto electrics experience have any ideas as to whether this could happen? Any help much appreciated!!! :D
Mike.
Mikee
Re: Led Strip Lights Under Shelving...
Postby ake » Tue Jul 23, 2013 7:40 pm
Yes you can do it, LEDs have a very low current draw, and you will probably find that you don't even need the standard lights so can disconnect them
Postby Mikee » Tue Jul 23, 2013 10:45 pm
Cheers Ake,
I decided to get some of these as they are 'sticky backed' and can be cut to size...
http://www.ebay.co.uk/itm/5M-cool-white ... 4ac73d3587
As far as I can work out the max current draw will be around 2A so I'm hoping they'll be fine to be wired direct to the loadspace lights, a simple + and - connection and hopefully I'll be in business!
Mike.
Mikee
Postby andycaca » Wed Jul 24, 2013 10:59 am
thats the same stuff ive used. dead easy to work with and sticks to any nice clean surface :)
2005 Mk6 Jumbo 2.4 115 350 aka "The Party Bus"
1988 Celica Sprint Special aka "The 500bhp Sledgehammer"© Fensport 2012
2003 KX250 aka "DeathWish™"
andycaca
Postby Mikeemikester » Wed Jul 24, 2013 12:19 pm
Good stuff Andy, thanks. Did you do the same thing as I intend to do?- if so does it work okay and did you wire it straight from the rear courtesy lights? Ta!
'10 SWB Lo Top 115ps Trend
Remapped by Image
Mikeemikester
