Radio Codes
Re: Radio Codes
Postby paulthechippy » Sat Aug 10, 2013 8:55 pm
Thanks guys, really appreciate your response.
I've just try holding in button 6 for 20 seconds, but the display is still showing 'locked 13'. It won't let me enter the code. But strangely, I pressed buttons 6 & 5 at the same time and DPS or DSP was displayed and the radio came on... a few seconds later, the display went back to 'locked 13' and no radio. Any more advice will be great. Thanks again.
paulthechippy
Re: Radio Codes
Postby Altransit » Sat Aug 10, 2013 9:41 pm
paulthechippy wrote:Thanks guys, really appreciate your response.
I'm pretty sure that "locked 13" means the the radio is effectively scrap, unless you know someone with the software to unlock it :(
Re: Radio Codes
Postby paulthechippy » Sun Aug 11, 2013 12:30 pm
Yes, I'm looking to buy one now. :(
paulthechippy
Re: Radio Codes
Postby andrusl » Sun Aug 11, 2013 12:51 pm
paulthechippy wrote:Yes, I'm looking to buy one now. :(
eBay listings
andrusl
Re: Radio Codes
Postby paulthechippy » Mon Aug 12, 2013 6:46 pm
Hello - me again...
I've managed to buy another set and the serial number is M172171
Thanks very much again.
paulthechippy
Re: Radio Codes
Postby topmanuk » Mon Aug 12, 2013 8:05 pm
paulthechippy wrote:Hello - me again...
6499 :wink:
topmanuk
Re: Radio Codes
Postby paulthechippy » Mon Aug 12, 2013 8:51 pm
That did it - excellent. You made an old man very happy! :D
Thank you.
paulthechippy
Re: Radio Codes
Postby iceberg23 » Mon Aug 19, 2013 9:03 pm
Hi all,
Can I please have a code for M133968 Transit 2001
Many thanks
Andrei
iceberg23
Re: Radio Codes
Postby APH » Thu Aug 22, 2013 11:54 pm
iceberg23 wrote:Hi all,
Many thanks
Andrei
Try 1625
(\__/)
(")_(")
this is bunny
APH
Re: Radio Codes
Postby Transitalways » Sun Sep 01, 2013 4:41 pm
ake wrote:If you need the radio code for your MK 5 or MK6 Transit simply post the serial number of the Stereo on this thread and someone will reply with your code
We can only do codes here for serial numbers beginning with an "M"
To find your serial number you need to remove the stereo, The serial number starts with M and you will find on the side of your stereo.
Or follow these instructions
Highlander250469 wrote:I posted this on the Scorpio forum many years ago, explains it all fully..
To obtain your radio code you will need the serial number of the radio, usually shown on the label on the right side of the radio.
eg. M123456
The radio will need to be at least partially removed to see this using the correct removal keys.
A request on the forum showing your serial number will usually produce the code fairly quickly.
Or the software can be downloaded from HERE
When running the software the following appears :
Enter your serial number then click on the large No. 5 Preset button on the bottom to generate the code.
To exit the software click on the large on/off button on the left
Where could I get hold of this software would be handy to have ???
To enter the code on the radio use the large preset buttons on the bottom of the radio (1-6) RDS 4000, 5000, 6000 etc.
eg. Code = 2487
press button 1 to cycle through the numbers until 2 is displayed.
press button 2 to cycle through the numbers until 4 is displayed.
press button 3 to cycle through the numbers until 8 is displayed.
press button 4 to cycle through the numbers until 7 is displayed.
press button 5 to enter the code.
If 3 incorrect attempts are made there will be a 30 minute delay before you can try again, the key has to be in the ignition position 1 during this time, removing it will reset the timer.
After 10 wrong attempts the display will show LOCK 10
Holding button 6 while turning the radio on will give you a further 3 attempts.
If these three are entered incorrectly the display will then show LOCK 13 and you will now need to get it reprogrammed
If you have a MK7 (serial number starts with V) you need to contact your Ford dealer for the code
Or you could ask Taz nicely
viewtopic.php?f=2&t=125916
taz666 wrote:I will post this as not a lot of people know that I do but I can get V codes for ford stereos, I need the part no which normally starts 6c1t-??????-?? and the V serial number P.M me and I will get back to you with code, please be patient I'm not on here every day :)
Transitalways
Re: Radio Codes
Postby bmax81 » Thu Sep 05, 2013 6:17 am
Hi pls can some one help me whit the cod for 4000 RDS serial no M 489671. Thank youuu
bmax81
Re: Radio Codes
Postby milkaga » Thu Sep 05, 2013 8:14 am
bmax81 wrote:Hi pls can some one help me whit the cod for 4000 RDS serial no M 489671. Thank youuu
Try code 8281
milkaga
Re: Radio Codes
Postby bmax81 » Thu Sep 05, 2013 10:48 am
Hi i have a ford transit and my radio is blocked,my radio is 4000RDS serial no is M489671.can some one help me whit the code .Thank you!!!!
bmax81
Re: Radio Codes
Postby milkaga » Thu Sep 05, 2013 11:13 am
bmax81 wrote:Hi i have a ford transit and my radio is blocked,my radio is 4000RDS serial no is M489671.can some one help me whit the code .Thank you!!!!
press 6 keep any second
milkaga
Re: Radio Codes
Postby bmax81 » Thu Sep 05, 2013 11:17 am
Thank you!!!!
bmax81
