what is this part
what is this part
Postby mastrum67 » Tue Sep 10, 2013 9:57 pm
Mates connect has bottom left fault light on dash on had codes read comes up say Egr fault been told it colud be this part bolted on to inlet manifold between soleniod what is it and where is best place to get one cheers Gary
2007 Transit Connect T220L 90 Swb Tdci
mastrum67
Re: what is this part
Postby mastrum67 » Tue Sep 10, 2013 10:00 pm
Van starts ok drives ok most of the time just holds back now and again
mastrum67
Postby paul2012 » Tue Sep 10, 2013 10:02 pm
That part is the EGR motor assembly with position sensor :wink:
Secured to inlet manifold with 4 screws.
Post the code, it maybe faulty or possible EGR valve possibly sticking abit :?:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby mastrum67 » Tue Sep 10, 2013 10:15 pm
Which part is the position sensor please
mastrum67
Postby liteace » Tue Sep 10, 2013 11:09 pm
mastrum67 wrote:Which part is the position sensor please
The position sensor is inside where the control motor is, its all one part
Please don't send me PM's, i can't access them, when I try I get this:
You are not authorised to send private messages
liteace
Postby mastrum67 » Tue Sep 10, 2013 11:16 pm
Any idea where I can get another one from also whats the black plastic part joined on to egr motor thanks Gary
mastrum67
Postby liteace » Tue Sep 10, 2013 11:47 pm
mastrum67 wrote:Any idea where I can get another one from also whats the black plastic part joined on to egr motor thanks Gary
The black plastic part is the motor & position sensor end cap + the internal electrical connections
liteace
Postby mastrum67 » Wed Sep 11, 2013 6:31 am
So the part I need is the egr motor correct the middle part .Cant find and listed on the net
mastrum67
Postby liteace » Wed Sep 11, 2013 8:34 am
You cant find it listed cause it sold complete with manifold, check these part numbers out:
Ford Part Numbers - 1563296 / 4M5Q 9424 CD
Im not saying they are 100% correct for your vehicle but it'll give you an idea
liteace
Postby paul2012 » Wed Sep 11, 2013 12:31 pm
The EGR position sensor in the Black end cap - see below :wink:
These are not available separately - Ford retails them as a complete unit with manifold :(
Be careful on which inlet manilfold you get there are 2 types available (One has a throttle position sensor & the other doesn't) :wink:
Although when buying the complete manifold with EGR assembly New they are very expensive (£400 +)
Here is a list where you can get a complete EGR motor assembly from. - The same part is used on Focus / C-max / Mondeo mk4
:arrow:http://www.ebay.co.uk/itm/FORD-TRANSIT- ... 3a84d9d989
:arrow:http://www.ebay.co.uk/itm/GENUINE-FORD- ... 2a312a48dd
:arrow:http://www.ebay.co.uk/itm/FORD-FOCUS-MK ... 4611576962
:arrow:http://www.ebay.co.uk/itm/FORD-FOCUS-1- ... 3a81fda867
:arrow:http://www.ebay.co.uk/itm/Ford-focus-07 ... 3a84e17da9
:arrow:http://www.ebay.co.uk/itm/2008-ford-foc ... 4d0ce4ca2e
:arrow:http://www.ebay.co.uk/itm/2008-FORD-MON ... 232e6f1fe6
paul2012
Postby mastrum67 » Wed Sep 11, 2013 10:09 pm
Thanks for the replys .l have ordered the top one in your links to eBay Paul thanks for that can I buy the gasket that goes between the egr & manifold or can I just smear a little gasket sealer on my gasket cheers Gary
mastrum67
cron
