2.5di in a mk7???
2.5di in a mk7???
Postby lancy » Fri Sep 13, 2013 11:05 pm
Hello there, my trusty old 190 xlwb has come to end of is time :(
and who I work for have asked me to get a fresher van but I not too keen on the problem s associated with them, seems to me u always need to have at least a grand spare incase of problems unless ur one of the lucky ones.
I no a di has bn put in a mk6 before and this is what I had in mind but was wondering is it possible to put one in the mk7??
I no thers issues with getting speedo working on mk6 but would it be easier to get it working on the mk7 as I gather its taken from abs unit?? also wondering if possible to fit the cable drive shifter to the old box??
Sorry to go on :? hope I bn clear enough and u can make sense of it lol.
many thanks sean
lancy
Re: 2.5di in a mk7???
Postby trigger » Fri Sep 13, 2013 11:35 pm
If you are gonna do that make sure you set your alarm an hour earlier for work :wink: :lol:
Mk5 Transit the daddy
trigger
Postby lancy » Fri Sep 13, 2013 11:44 pm
whys that? I also got turbo bit to put onto the engine two if that's what you getting at
lancy
Postby trannynz » Sat Sep 14, 2013 8:48 am
I have a di and love it. But I wonder when your have to call it a day on the di's? Maybe in ten years we will be looking on the mk7 as a good motor!
trannynz
Postby limitedblack » Sat Sep 14, 2013 8:57 am
It would take too much rewiring I would think. MK 7 has the dreaded BCM module that nearly everything goes to, plus the speedo, ecu, and fuel pump are all coded to this. Simple things like airbag light, abs light, and central locking won't work without this infrastructure in place.
Even the load sensing valve for braking is now an electronic algorithm that is part of the abs esp system.
If you gutted the whole van and went basic it would still fail an mot without the airbag light or a catalytic converter ect.
Happy Easter
limitedblack
Postby blue estate » Sat Sep 14, 2013 9:56 am
WHY !
blue estate
Postby dieselhead123 » Sat Sep 14, 2013 11:14 am
trigger wrote:If you are gonna do that make sure you set your alarm an hour earlier for work :wink: :lol:
Not if you put my engine in you won't :wink:
TBH though, what a waste of a GOOD engine :lol:
Postby limitedblack » Sat Sep 14, 2013 6:37 pm
There's nothing wrong with a TDCI that £2000 can't fix :lol:
Happy Easter
limitedblack
Postby andypdq » Sun Sep 15, 2013 12:24 pm
It may be that the non engine systems will still work with all the engine wiring unplugged, in which case it should be relatively easy. You would have to fit the Di speedo though.
I suppose the easiest way to find out would be to unplug all the engine wiring from a Mk7, then tow it down the road with ignition switched on and see what works and what doesn't. :idea:
Andy.
The first Mk 6 mechanical TDDI, giving electronics the finger, since April 2013
Perfection is reached, not when there's nothing left to add, but when there's nothing left to remove.
YouTube https://www.youtube.com/channel/UCNypVH ... dKUN5eJDyQ
andypdq
Postby lancy » Sun Sep 15, 2013 12:55 pm
hmm interesting, wasnt thinkin o ftakin out a working engine out of one but to replace a nakerd one if I found one cheap enough.
lancy
Postby andypdq » Sun Sep 15, 2013 1:18 pm
lancy wrote:hmm interesting, wasnt thinkin o ftakin out a working engine out of one but to replace a nakerd one if I found one cheap enough.
You could hire one for a day and try it. :lol:
andypdq
Postby darkbluevanman » Sun Sep 15, 2013 1:46 pm
Anyone bought a mk7 and thinks, I'd give all this up to go back to a di?? anyone???
darkbluevanman
Postby blue estate » Sun Sep 15, 2013 2:43 pm
darkbluevanman wrote:Anyone bought a mk7 and thinks, I'd give all this up to go back to a di?? anyone???
They must have been pissed, high as a kite or sectioned :lol: :lol: :lol: :lol:
blue estate
Postby afireinside- » Sun Sep 15, 2013 2:56 pm
I own a smiley recovery truck and also occasionally usea friends 140ps mk7 recovery truck
My smiley has a turbo and manual fuel pump wound up so it pulls pretty well, The mk7 has good torque too but i find it has a very narrow powerband and only moves when its on boost.
I prefer my smiley for reliability and just driving town to town but the mk7 is by far more comfortable on the motorway with 6 gears you can cruise at 90.
If I just did motorway driving i think i would go for a mk7 but as most of my jobs are local I'll stick with my old faithful di
afireinside-
Postby trigger » Sun Sep 15, 2013 3:04 pm
I used to think like that but now i have a mk7 no, i still love the mk5's but if i ever had to go back to one i would want a mk7 engine in it
trigger
