Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Re: Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Postby dieselhead123 » Mon Aug 19, 2013 12:18 am
Glad you got the old girl going better, good news about getting another bonnet 8)
Luke wrote:but the big news is :!: :!: :!: :!: - i took it for a little run up the road with the boost leak sorted - and it spun up under hard acceleration - which it hasnt done since i had the cossy in :mrgreen: :mrgreen: so i have high hopes 8)
after Transitmania 5 is over i'm going to sort out another drag meet to test it if anyones interested??? stu also fancy's taking the YB mk6 out again after fixing his turbo he thinks he can improve too :mrgreen:
Count me in on that one mate, SMOKING :lol:
Postby AlanN » Mon Aug 19, 2013 7:49 am
Great news all round then Luke :D
Postby Luke » Mon Aug 19, 2013 8:58 pm
good day today started off with me collecting the charge cooler back from being modded 8)
then later off managed an MOT pass 8) 8)
seats out now and all packed for Transitmania............well started to pack :oops: :lol: :lol:
Postby limitedblack » Mon Aug 19, 2013 9:21 pm
Well done, see you there :)
Happy Easter
limitedblack
Postby dieselhead123 » Tue Aug 20, 2013 8:13 am
Luke wrote:good day today started off with me collecting the charge cooler back from being modded 8)
Good news all round there mate.
make sure you wash the cooler out, mine is in a bucket soaking!
See you at THE show :D
Postby robbie.cee » Tue Aug 20, 2013 12:15 pm
dieselhead123 wrote:Glad you got the old girl going better, good news about getting another bonnet 8)
Well done Luke!
Count us in for another drag meet!
Need to sort out my old lump should be loads faster than the pinto!?!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Luke » Sun Sep 01, 2013 10:51 pm
got the chargecooler mounted today - just need 1 more hose (ordered) then i can pipe it up :D i also need a pump and a rad - i'm going to fit a punto turbo rad as that fits neatly into my space infront of the rear axle :D
i did make some lovely brackets to mount it but the photos have turned out crap :| obviously its still on the bypass pipe but its in the final position here :D
Postby dieselhead123 » Sun Sep 01, 2013 11:15 pm
Cracking work there as always, you have so much room under there with your van, :mrgreen:
Rear mounting the rad will give you more water capacity and help with cooling even more, you WILL notice the difference!
Postby Luke » Sun Sep 01, 2013 11:53 pm
cheers Tim 8) btw whats that part number of the high capacity bosch water pump :?:
Postby dieselhead123 » Mon Sep 02, 2013 12:09 am
Got it written down at work mate, I'll pm you again in the morning.
You will need the high capacity one given your extra length pipe runs.
Postby dieselhead123 » Mon Sep 02, 2013 12:16 am
I'll pm the number in the morning mate, written down at work.
The larger capacity will help given your longer hose runs.
Mount the pump at the lowest point in the system as they don't self-prime.
Postby Luke » Sun Sep 15, 2013 10:29 pm
piped up today :D just need the hose clips then on to the water pipes :)
Postby limitedblack » Tue Sep 17, 2013 5:37 pm
Luke wrote:piped up today :D just need the hose clips then on to the water pipes :)
Nice to see it with an air filter, I'll sleep better now :)
Happy Easter
limitedblack
Postby g-man » Tue Sep 17, 2013 7:34 pm
is that what it is......... :lol:
g-man
Postby dirtydog » Sat Sep 21, 2013 10:35 am
I thought a tortoise has been fitted :wink:
dirtydog
