Puk, a troublesome fairy!
Re: Puk, a troublesome fairy!
Postby FredTransit » Thu Oct 17, 2013 10:48 pm
chuffin ell. It spat a valve seat WTF???
FredTransit
Mk2 Trannyist
Postby Muttley » Thu Oct 17, 2013 11:05 pm
Yeah, no2 inlet valve seat came out of the head and jammed the valve open!! Freaky fault, never seen that one before :shock: . I took the good cam and followers from that head and put them on the other head we had. I left Jono with full instructions on how to refit the head etc, how did u get on matey?? :)
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby jonochap » Thu Oct 17, 2013 11:30 pm
Worked as hard as i could til dusk. All the studs were in the old head so took ages to get the first set off the old one. So far...head gasket on and sealed, exhaust manifold on, timing belt on, water pump on. Head gasket went on easy (scared) but having set up the exhaust manifold i got the furthest exhaust gasket upside down...grrr...and it had to be the one with the stud and the nut so no easy way to remove!
Timing lines you left all matched up when the cam belt went on and the two front lobes (?) were up. Bill the sailor gave some sage advice on how to get studs out...oh the joys!
Complicated bits to do tomorrow though :(
jonochap
Postby jonochap » Fri Oct 18, 2013 2:22 pm
Lunch break, rocker cover finally went on! Carbs in place, exhaust down pipe re mounted...cant remember how to pipe carb so stopping for piccys :) so far so good but no idea if what i have doned is right! Only time will tell now :)
jonochap
Postby Muttley » Fri Oct 18, 2013 8:53 pm
Well done indeedy matey, PUK now a runner on all four!!
Muttley
Postby jonochap » Sat Oct 19, 2013 7:28 am
Yip :) test drive all ok so far! Will post engineering modification later today after photo shoot. Out to check fluids later then off to waltham abbey for maiden voyage
jonochap
Postby blue estate » Sat Oct 19, 2013 8:44 am
You really need to find a four leaf clover, hang a 100 horse shoes up on the van to give you more luck :lol:
Have a happy test drive today :D
blue estate
Postby robbie.cee » Sat Oct 19, 2013 8:56 am
Well done Jono and big up Muttley!
Be taking my van for first drive since leads fitted after transitmania today!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby mealic » Sat Oct 19, 2013 9:15 am
Jono, PUKs story really is a tale of woe. Hope you finally have it sorted now and can enjoy.I suppose it was a case of having to get involved in re-building the head and re-fitting but you have learnt a lot I`ll bet. That cuppa will taste even better knowing that you`ve done it yourself. Well done mate.
`04 2.3 petrol/LPG
mealic
Postby jonochap » Sat Oct 19, 2013 10:21 am
Aw, thanks guys. As always, without the help and encouragement, knowledge and advice of some great people on here, i really would be nowhere now!
Well, work on the other bits didnt stop. A very good friend fitted a new drivers seat and track rod ends last week, steering is almost perfect! I was worried that not driving him would dry the servo but so far so good. Although the engine is now black red and blue i think it has a little bit of you all and so a lot of love in it, so who needs clovers and horseshoes ;)
Btw...Anyone know any rural irish blacksmiths???
jonochap
Postby Muttley » Sat Oct 19, 2013 8:34 pm
Long live PUK, and Jono :mrgreen:
Muttley
Postby robbie.cee » Sat Oct 19, 2013 8:54 pm
Best tell us what day to.do am Essex meet then mate !
Had
MAKE IT FIT
robbie.cee
Postby jonochap » Sat Oct 19, 2013 10:36 pm
Hey, we made it!!! Couple of minors...odd whistle when on idle and i dont think the exhaust is on right still! Grrr but hey...we made it!
Meets work well on any day but thursday for me...still like the idea of a saturday morning coffee and doughnut though :)
jonochap
Postby jonochap » Sun Oct 20, 2013 1:10 pm
Just so you know...if you tighten up the middle bolt thats pouring water out and replace the stud you missed on the inlet manifold, the whistling stops :)
jonochap
Postby robbie.cee » Sun Oct 20, 2013 4:00 pm
He he always helps!
Right ill look to do a sat meet soon then !
Had
MAKE IT FIT
robbie.cee
