MK 6/7) Single or Dual Mass Flywheel
Re: MK 6/7) Single or Dual Mass Flywheel
Postby JoelHatton » Mon Oct 21, 2013 12:12 am
So when i had my flywheel done earlier this year i made the right decision sticking with a DMF?
JoelHatton
Postby ake » Mon Oct 21, 2013 7:24 am
JoelHatton wrote:So when i had my flywheel done earlier this year i made the right decision sticking with a DMF?
I would have said so, however opinion, as always, is divided
Postby Jamysumm » Mon Oct 21, 2013 10:35 am
ake wrote:
JoelHatton wrote:what are the benefits of changing to a smf?
Increased vibration, potential damage to gearbox input bearing, but hey you might save £50
Id like to point out that I replaced the dmf with a smf as that's what should of actually been in it to begin with , and as far as I know there is no benefit to putting a dmf in an 85ps transit anything over100ps then yes but thats how they come from the factory anyway soo
Jamysumm
Postby Kaymar » Sun Apr 09, 2017 2:19 pm
I have a SMF fitted as a replacement flywheel during a gearbox replacement; was told being simpler was more reliable. The DMF that came out was almost in two parts. I don't think it is quite as smooth as old one. Only issue so far (40,000kms) is a replacement starter motor sometimes whirrs against the flywheel instead of engaging (engages 90% of time). Was told of a critical distance between the pinion and face of flywheel that may be being compromised by different flywheel. Strange!!
Kim
Kaymar
Postby Brettbear63 » Mon Jun 07, 2021 7:50 am
Hello , I had a 2.0 tddci Mondeo which had a Dual Mass , replacement was about a Grand , is the 2.4 TDCI dmf in my Transit 330 rwd a similar kind of price ?
thank you.
Brettbear63
Postby Altransit » Thu Jun 17, 2021 6:58 pm
Brettbear63 wrote:Hello , I had a 2.0 tddci Mondeo which had a Dual Mass , replacement was about a Grand , is the 2.4 TDCI dmf in my Transit 330 rwd a similar kind of price ?
thank you.
Even my 1.6TDCi Focus was nearly a grand, but that included a master cylinder, as well as clutch and DMF :(
Postby j1mm333 » Fri Jul 07, 2023 6:52 pm
Hi all. Noob here. Is there a way to tell whether a SMF kit has been fitted somewhere along the way? I have a 2004 350LWB 90HP 2402cc
Thank you kindly
j1mm333
