Big-kev1975 wrote:Well just a quick update I've had the injectors leak back tested and all four are leaking back too much the guy said he had found some metal swarf in the new fuel filter which I've done about 300 miles sins it was changed but he did say that the pump is producing good pressure so looks like its 4 replacement injectors
When my pump packed in it knackered the injectors too. No real warning until it went. If your looking for a set of injectors I got mine off dieselboy1978 for only £300 which was a big saving. Got them next day by special delivery and just return the old ones once removed. Maybe worth sending him a PM unless you have a more local supplier.
