Question about split charge relay
Postby dht » Fri Nov 08, 2013 1:22 am
I bought a Smarcom split charge relay from ebay but it does not seam to charge my leisure battery. I wired the split charge relay according to instructions, but when the motor is running there is no +12V feed to "Ext. Bat". There is a continuous "click" sound from the split charge relay.
The seller didn't reply to my messages.
Please explain to me how does the slit charge relay work and how I can solve the problem.
dht
Re: Question about split charge relay
Postby angeleye » Fri Nov 08, 2013 2:30 am
Have you tried the search button or the camper van section there's a fair amount on relays on forum sure you will find your answer
angeleye
Postby limitedblack » Fri Nov 08, 2013 8:00 am
Split charge is a function that connects your leisure battery once your running voltage goes over about 13.4v, this means only when engine running and alternator up to correct voltage output. Some also limit current to avoid cable damage.
Happy Easter
limitedblack
Postby craig8661 » Fri Nov 08, 2013 10:58 am
Did you fit an earth to the relay from the body daft question but have seen it where they forget the neutral on one side
craig8661
Postby dht » Fri Nov 08, 2013 2:17 pm
I checked the wires, they are all correct.
How can I check if the split charge relay is in working order?
dht
Postby craig8661 » Fri Nov 08, 2013 2:28 pm
Disconnect wire from relay to lesure battery start van and test for 12 volts or more on the wire you disconnected
craig8661
Postby dht » Mon Nov 11, 2013 5:04 am
There is a "Adjustment" in the Smartcom split charge relay. What does this adjust? How and when we can make some adjustment?
dht
Postby craig8661 » Mon Nov 11, 2013 6:21 am
I'm not sure what the adjustment is as my relay didn't have that to me relay should be wired from the main battery to the left so live and then neutral could be from battery or body then aux to other battery live then earth the other battery to the body
craig8661
Postby limitedblack » Mon Nov 11, 2013 7:48 am
It will be that running voltage probably.
Happy Easter
limitedblack
