AlanN's MK3 V6 Day Van
Re: AlanN's MK3 V6 Day Van
Postby BROWNYS V6 » Tue Nov 12, 2013 11:52 pm
what diff u got 3.9 ? chuck a type 9 innit, job done :D
BROWNYS V6
Postby AlanN » Wed Nov 13, 2013 10:29 pm
Yep, still got the 3.89 you fitted, still not check oil :shock: What advantgages are there with a type 9 other than the stick will be closer. Their getting a little scarce now and loads of money!!!
Postby BROWNYS V6 » Wed Nov 13, 2013 11:49 pm
just thought it would be an easier way too go, 2.8 flywheel,(easy) 2.8 box(easy but costly maybe) mod ur prop(just the front half) make a gearbox crossmember or add a bit on your original one like i did (easy) unless you got all the hard to find bits to connect a v6 to an mt75 of course :wink:
but then you still got to find the right mt75 :?
type 9 looks easier to me, but then im biased :lol:
good luck wiv whatever you decide :wink:
this ones quite cheap at the mo, needs the tailsection swopping out though for a 2wd one :idea:
.ebay.co.uk/itm/FORD-SIERRA-2-8i-XR4X4-GEARBOX-COMPLETE-TYPE-9-HEAVY-DUTY-GOOD-WORKING-ORDER-/190968251156?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c76984314
BROWNYS V6
Postby AlanN » Thu Nov 14, 2013 12:23 am
Engine is already sitting on SVO mounts and I now have flywheel and adapter... just need gearbox, sold my one and lastly prop, coz I dont think I saved mine :roll:
Postby BROWNYS V6 » Thu Nov 14, 2013 12:28 am
mt75 then, ur halfway there :wink: aint u got a box laying about to chuck in it ? :)
u only need the front bit of prop.
BROWNYS V6
Postby AlanN » Thu Nov 14, 2013 1:11 am
Probably have a prop here somewhere, but I dont think we have a box...
Postby dieselhead123 » Thu Nov 14, 2013 1:56 pm
AlanN wrote:Tell me more Tim :D
As we all know, the major internal parts of the Mt75 box are interchangeable between casings, that is the gear clusters.
So, if you have established that you need to use a Transit Mk3/4/5 Mt75, (you could use the Cologne Mt75 with the smaller flywheel,clutch and starter, no need to use the SVO adapter plate then), this would place the gear lever further back though, it is just a case of stripping your chosen box and installing the gear clusters of your choice.
According to Bortaf, a higher fifth gear is available in the 2.5 diesel scorpio box, quite rare though, there are different gear sets in the Mk3/4/5 di box, possibly another available in the Mk5 DOHC box, possibly other different ones available in Mk6 Mt75's, BUT, plenty more available in 'car' boxes.
The point being is that you are well advised to widen your search outside the Mk3/4/5 model range as the internals will interchange.
Postby limitedblack » Thu Nov 14, 2013 6:27 pm
I'm confused (easily), this box is meant to be for the v6, but fits a mk6?? I get the casting bit, just seems strange to have one name for different boxes.
Happy Easter
limitedblack
Postby dieselhead123 » Thu Nov 14, 2013 8:38 pm
limitedblack wrote:I'm confused (easily), this box is meant to be for the v6, but fits a mk6?? I get the casting bit, just seems strange to have one name for different boxes.
Confused?
Probably all that Tripe!
All the boxes referred to are Mt75's, all Ford did was change front casings to alter bell housing configurations and alter gear selectors to move gear lever positions.
Alan has a V6 cologne, so a V6 box will fit the engine directly, or he can use a Di bell housing and an SVO adapter, as Nick has done on his.
The 'car' type Mt75, all the V6 bell housing types are this type, will place the gear lever further back in the van than the van type, but there are two types of these, DOHC bell housing and Di bell housing patterns.
To further confuse matters, the Mk6 is really a 'car' box, given that the selectors are altered to place the gear lever further back than in the Mk5.These are available with two different bell housings, DOHC and Duratorq!
But, fortunately for us, Ford decided to make the gear cluster assemblies interchangeable between gearboxes, giving us a wide range of possible 'hybrid' boxes to 'play' with!
Postby limitedblack » Thu Nov 14, 2013 9:18 pm
Thanks, read it 3 times now ;)
Happy Easter
limitedblack
Postby martynx » Mon Dec 02, 2013 10:25 pm
Intriguing !! & the MTX75 ?
martynx
Postby dieselhead123 » Mon Dec 02, 2013 11:01 pm
Apparently, the MTX75, front wheel drive version does share some common internal componants, exactly what, I am unsure, but likely some of the gear cluster parts.
The '75', referes to the distance between the main/output shaft and the layshaft, 75mm.
The point being is that they, (the rear wheel drive ones at least), are all 'hybrids', and many others that Ford had no use for could be assembled.
Postby madbri » Sat Apr 19, 2014 8:33 pm
any more updates?
madbri
Postby cozzyxr3i » Mon Apr 21, 2014 3:37 pm
First Post on the forum, I love this van AlanN, I also want to know if there is anymore updates
cozzyxr3i, Xbox Gamer (Feel Free too add me) Transit van fan, Mechanical Novice, probably one of the youngest on the site.
R.I.P Kurdt Cobain from Nirvana, Paul Walker from Fast And Furious 1/3-6 and R.I.P The Beatles whom are dead.
cozzyxr3i
Postby robbie.cee » Thu Apr 24, 2014 9:43 am
He washed it.and waxed it the other day!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
