Lowering the new Transit custom?
Re: Lowering the new Transit custom?
Postby Goliath » Sat Dec 07, 2013 3:41 pm
keeff wrote:Your set up looks the same so you will need to put a block as you can see in the photo . The ubolts need to be the correct width and the block.
You do not need to change the ends of the springs.
I should be getting my van in the new year and be able to measure the width and spacing of the van ubolt if they are the same you can get one like mine or different heights of the shelf. Ford are good at keeping things the same over the years that's how I Can fit a 2004 focus engine to a type 5 gearbox ( rear wheel drive) and fit it in a 50 year old ford anglia
Getting replacement springs would be better if you can get them but if you use blocks you can pop them out if you need to go back to the dealer
I do not really understand what you mean, were does the blocks go? do i have to put the leafsprings under the axle?
Goliath
Postby g-man » Sat Dec 07, 2013 3:52 pm
looking at the depth of that beam to flip it would lower it way too much.....as said get the springs reprofiled 30/40mm 8)
g-man
Postby keeff » Sat Dec 07, 2013 5:50 pm
Sorry I could not see you photos on my ipad and my photo did not go with reply
I don't think it will work as they have put spring on top not like the old days. But it does make it stronger.
This is how ford use to build so you could just put a spacer in .A space in yours would make it higher.Image
keeff
Postby DrDeAtH » Sun Dec 08, 2013 1:27 pm
Decambering the springs is the SAFEST way to do it.
Although why you would bother in a van that you load up with weight is beyond me.
Best to go with an air suspension setup anyway. At least you can adjust the ride height.
DrDeAtH
Postby invita » Mon Dec 09, 2013 7:22 pm
DrDeAtH wrote:Decambering the springs is the SAFEST way to do it.
Mine seem to be too low after my tools got inside.
Is it possible to get airsuspension to the new custom ?
invita
Postby Mike » Mon Dec 09, 2013 8:21 pm
Picture?
Mike
Wind up merchant!
Postby DrDeAtH » Mon Dec 09, 2013 11:35 pm
[quote="invicta]
Is it possible to get airsuspension to the new custom ?[/quote]
You would have to go to somewhere like Rayvern who will do a custom setup. But it will cost a couple of grand at least....
DrDeAtH
Postby invita » Wed Dec 11, 2013 10:25 am
DrDeAtH wrote:[quote="invicta]
You would have to go to somewhere like Rayvern who will do a custom setup. But it will cost a couple of grand at least....[/quote]
Thank you.
Il wait until something comes on the marked ( plug and play )
I think the car is to low when loaded and also the tailgate shocs seems too be to week now its getting colder.
So all in all you have to be carefull not to bang your head in the tailgate in wintertimes :-(
Michael
invita
Postby DrDeAtH » Wed Dec 11, 2013 10:48 am
That will be a long wait.........
DrDeAtH
Postby Mike » Wed Dec 11, 2013 10:49 am
DrDeAtH wrote:That will be a long wait.........
And if it's too low with your tools in it, it could be overloaded?
Mike
Wind up merchant!
Postby yasser » Thu Dec 12, 2013 1:20 pm
When I had a Coach built campervan on the fiat Ducato chassis. It was a Six berth so quite big and so was always running to full weight. I fitted airride (brand name) air suspenion for a couple of hundred quid. They fixed on the chassis and replaced the bump stop. These worked to assist the ride and levelling of a fully loaded van with a large over hang at the rear, they didn't replace the leaf spring. If you were to reshape the existing spring to get a lower ride you could (in theory) us the air ride to assist the springs. Another advantage of these was the ability to alter each side indepenantly to get the right height level and adjustable for about 6". So if you were to load the van you could adjust to the correct ride height.
310 DCiV L2 Limited 155
yasser
Postby yasser » Thu Dec 12, 2013 5:51 pm
This is a link ( hopefully) for above, plus they do come up on ebay when campers are scrapped. Have a look at this ebay item number https://www.ebay.co.uk/itm/290975838027
http://airride.co.uk/air-suspension-exp ... basic-kit/
yasser
Postby invita » Thu Dec 12, 2013 9:49 pm
It is not overloaded just around 800 kg.
Air suspension.
I think its already there
http://www.driveriteair.com/catalog/sea ... 5&pageId=1
invita
Postby Einteriors » Sun Dec 29, 2013 6:21 am
Hi All,
I am a Nub to this forum as I am doing some research on the new transit before I buy.
Lowering is one of my must haves for which ever van I decide on. Looking at the photos above of the leaf spring assembly, I see that the leaf spring is mounted above the axle. Which means that lowering blocks will not work. The leaf needs to be below the axle to so that block can be installed above the leaf and below the axle, moving the axle closer to the body. Installing a block according to the pics above would push the axle away creating an even bigger wheel arch space. Hope this makes sense...
Einteriors
Postby Goliath » Sat Mar 22, 2014 4:22 pm
bumping this thread a bit..
Still no bolt on loweringkit to buy somewere?
Goliath
Return to Transit Custom
