Speed limit on campervan
Postby john kyte » Sun Dec 15, 2013 4:01 pm
The speed limit on camper up to 3.05 tons on an A road ,is 60 MPH
What I didnt know is that if you are carrying items to exhibition,,ie,, stationary engine---oil painting etc,,,the limit is 50MPH
john kyte
Re: Speed limit on campervan
Postby ake » Sun Dec 15, 2013 4:05 pm
Because it becomes a goods vehicle :!:
Postby john kyte » Sun Dec 15, 2013 4:07 pm
What about carry a months shopping ??
john kyte
Postby duvet » Sun Dec 15, 2013 4:11 pm
john kyte wrote:The speed limit on camper up to 3.05 tons on an A road ,is 60 MPH
only if commercial use of any vehicle makes it a goods vehicle.
who told you that the limit drops?
only reduction I know if if you are towing
ex-network rail 2007 mk7 100 LWB 350 8 seat.
buses stop at bus stations, trains stop at train stations....... on my desk i've got a workstation
duvet
Postby blue estate » Sun Dec 15, 2013 4:27 pm
The op is right :wink: see link http://uk.search.yahoo.com/r/_ylt=A7x9Q ... eed-limits
blue estate
Postby duvet » Sun Dec 15, 2013 5:35 pm
well I only ever carry goods for the "exhibition" in a trailer.......
duvet
Postby john kyte » Sun Dec 15, 2013 6:01 pm
Nobody told me----but you can read it on the net
john kyte
Postby Seriously Limited » Sun Dec 15, 2013 6:12 pm
It's bonkers isn't it? You can drive a camper at 70 on a derestricted dual carriageway at 70, an unladen Transit Connect only 60. Also larger HGV's on Motorways should only be doing 60 unless I've read it wrong. Seen very few of them adhering to that limit.
T230 Limited, Clifford alarm, sat-nav, rear camera, HID headlamps, front park sensors, leisure battery & onboard charger, fused 12V distribution, RCD 240V distribution, diesel heater, carpeted, insulation & trim, LED lighting
Andy W Midlands
Seriously Limited
Postby duvet » Sun Dec 15, 2013 6:14 pm
true... I just read it the wrong way.
that you can gain 10mph when you turn a commercial vehicle into a campervan .... except if you are using it as a commercial.
rather than you lose 10mph.
how though the gatso or SPECS (as its unlikely you'find a real policeman) will know what you have inside is a mystery
duvet
Postby blue estate » Sun Dec 15, 2013 6:17 pm
"It's bonkers isn't it? You can drive a camper at 70 on a derestricted dual carriageway at 70, an unladen Transit Connect only 60. Also HGV on Motorways should only be doing 60 unless I've read it wrong. Never seen them adhering to that limit"
Unless the HGV is forgein it can't do over 56mph and have not been able to since early 1990's all HGV's are restricted to 56mph
blue estate
Postby Seriously Limited » Mon Dec 16, 2013 2:35 pm
Interesting, the number of artics I see on the M5 quite happily keeping up with the other traffic, they're certainly not doing 56mph.
blue estate wrote:"It's bonkers isn't it? You can drive a camper at 70 on a derestricted dual carriageway at 70, an unladen Transit Connect only 60. Also HGV on Motorways should only be doing 60 unless I've read it wrong. Never seen them adhering to that limit"
Andy W Midlands
Seriously Limited
Postby john kyte » Mon Dec 16, 2013 4:15 pm
I dont see 40 footers[artics] doing more than 56 on motorway,,or anywhere else. Maybe a touch more if downhill
Dont forget that your speedo is most likely 5 mph fast-----so is the mileage meter,,,so if you think tou are getting 60 MPG,,you are only getting 55
Foreign artics are also governed to 50
john kyte
Postby ake » Mon Dec 16, 2013 9:25 pm
Even more interestingly, the quoted 3.05 tons in un laden, so I reckon even mine can scrape under that and allow me to drive my bigger heavier less stable vehicle faster than my shorter lower more stable Transit 260 :? :? :?
Postby James1123 » Sat Feb 08, 2014 8:44 am
Well I have been passed on the a14 by a lorry. It wasn't a 40ft arctic, but it was a 4 axle tipper. I was doing 70 and he came past me and disappeared out of sight very quickly!!
My van was empty and he must have made me move a foot to the left!!!
2000 MK5 SWB Semi Hi-Top 76ps TDI
James1123
