Punto443 wrote:Have you checked/substituted the little relays under the header tank?
Did it have a towbar?
angeleye wrote:They have one flasher unit for indicators/hazards which prob still is the problem,try swapping it with a someone else ,the two relays are just to switch the system on
andypdq wrote:angeleye wrote:They have one flasher unit for indicators/hazards which prob still is the problem,try swapping it with a someone else ,the two relays are just to switch the system on
The flasher unit is two units in one, that's why hazzards work and indicators dont. Exactly the same thing happened to mine. Replacement units are only available from Ford and are fecking expensive, I modded mine to work with an old three pin unit.
See viewtopic.php?f=5&t=132954
Andy.
NickandClairsTourneo wrote:Thanks; I jiggled the current unit and it seems to have fixed it...for noweBay seem a good shout for new ones
Users browsing this forum: Altransit
