NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby gt_addict » Wed Jan 15, 2014 3:58 pm
If you've got a number for the non heated ones Paul that would be great. I could only see the heated ones further back in the thread.
gt_addict
Postby paul2012 » Wed Jan 15, 2014 4:03 pm
gt_addict wrote:If you've got a number for the non heated ones Paul that would be great. I could only see the heated ones further back in the thread.
No problem m8 :wink:
NON HEATED washer Jets - Ford Part No F5148413
HEATED washer Jets - Ford Part No F5148412
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby gt_addict » Wed Jan 15, 2014 8:53 pm
Cheers mate :) I'll be ordering some of them soon, the focus ones I've got work ok, but if it can be improved with proper ones that would e better.
gt_addict
Postby doebag » Wed Jan 15, 2014 10:35 pm
Paul, further back in the thread, you posted the part number for the sub-loom and how to connect it.
Is the connector there on all Connects? Mine is a 58 plate LX with heated screen and mirrors, so guessing the connector is in place.
doebag
Postby paul2012 » Thu Jan 16, 2014 8:53 pm
doebag wrote:Paul, further back in the thread, you posted the part number for the sub-loom and how to connect it.
No it not there on all connects, although it should be present on yours, plug should be under N/S scuttle panel.
Fuse for heated washer jets is F41 10A for 2006-2009 connects :wink:
For 2003-2006 connects F53 10A
paul2012
Postby Ploen » Mon Jan 20, 2014 2:17 pm
Paul,,....
you put a QYBA (mondeo 125PS) engine in youre TC......
was that including turbo and feul system???
Just Connecting
Ploen
Postby liteace » Mon Jan 20, 2014 2:53 pm
Ploen wrote:Paul,,....
I think Paul was thinking about putting a mondeo 125PS engine in as he said in this post:
viewtopic.php?f=54&t=128295&start=90#p1090849
He's new engine that he got:
viewtopic.php?f=54&t=128295&start=135#p1096828
Is out of a 07, 90ps connect, I know the guy he bought it from up in Lincolnshire, small world :wink:
Please don't send me PM's, i can't access them, when I try I get this:
You are not authorised to send private messages
liteace
Postby paul2012 » Mon Jan 20, 2014 4:11 pm
:shock: :lol: :lol: :lol:
That's what you think :roll:
paul2012
Postby paul2012 » Mon Jan 20, 2014 4:33 pm
If you have a 110ps connect. QYBA engine complete with fuel system & turbo is a direct fit with no modifications & will run at 110ps. This it due to Connects calibration on ECU.
For a 75/90ps connect from 2006 onwards, again engine is a direct fit BUT to run at 110ps...
Forward section of exhaust/cat has to be replaced to one for VNT turbo & extra wiring (5 wires) added to ECU for VNT turbo & then load connects 110ps calibration onto ECU.
For 2003-2006 connects complete vehicle wiring loom (engine bay, dash & body loom) will require replacing with ones from a 2006 onwards model.
Due to different ECU & Fuel systems.
I've already tried running Mondeo 125ps calibration. Problem I have is PATs (immobiliser) won't reprogram - keeps coming up as Vehicle ID/Type mismatch so engine won't start :(
Plus ECU was looking for further equipment that's not fitted, cDPF is one of them :(
Although engine starts & runs no problem using connects 110ps calibration. :?
I will continue to work on getting Mondeo 125ps calibration to work & if I can get it to work then it would be a bonus - Cruise control then can be added 8)
paul2012
Postby paul2012 » Thu Jan 23, 2014 12:51 am
Finally Bagged a alternator from ebay £50 :D
Looks to be a fairly new one :mrgreen:
Hopefully it should work ok.
paul2012
Postby Brains_transit » Thu Jan 23, 2014 3:27 am
Big saving made there :D
Brains_transit
Postby Db89 » Sat Jan 25, 2014 8:44 am
My engine came yesterday, with what looks like a new-ish one on, plus, I bought a brand new one for my connect last year. So now I have 2 good alternators. If I would of known, you could of had one of mine cheap Paul, for helping me out with my swap.
Db89
Postby paul2012 » Sat Jan 25, 2014 7:57 pm
Db89 wrote:My engine came yesterday, with what looks like a new-ish one on, plus, I bought a brand new one for my connect last year. So now I have 2 good alternators. If I would of known, you could of had one of mine cheap Paul, for helping me out with my swap.
Not to worry :D
Would be best if you kept it as a spare, just incase alternator being used fails later on 8)
paul2012
Postby Db89 » Sat Jan 25, 2014 9:38 pm
Not to worry :D
Yeh, no doubt one will be no good out of the 2.
I'm glad my new engine came with the alternater and mount, as I broke mine somehow
Db89
Postby paul2012 » Sat Jan 25, 2014 10:14 pm
As mentioned on page 21 of this thread. Regarding change in mounting bracket for accelerator pedal on connects from 2006 onwards.
I checked with Ford to get a new one, Unfortunately they don't list them :shock:
So I obtained one from 2009 connect.
Simply drilled out spot welds to remove. :wink:
paul2012
