Fiamma f45s awning
Fiamma f45s awning
Postby matt86_wd2 » Fri Jan 24, 2014 8:55 am
Has anyone fitted one of these awnings to there van ? How easy is it to do ? How was it fitted nut and bolt or use rivnuts ...
My van is a lwb mk6 high top so lots of roof space I can get a 3meter awning on easy !
Also what height from the ground was it to the bottom of the brackets ?
Matt
matt86_wd2
Re: Fiamma f45s awning
Postby Jambofive » Fri Jan 24, 2014 10:16 pm
hi matt very easy just 3 brackets that bolt to side of van there are different types of brackets to suit different vans(check fiamma website) then the awning just hooks on these with retianing bolt underneath u will need a second pair of hands to help lift awning into place as it quite long and heavy. can b done in under an hour or two
if your buying new check the fiamma centre online they were £100 cheaper than anywhere else a looked i bought 3m f45s zip think was about £360 inc delvery
as for the height u can have it watever suits you as the legs that fold down are adjustable with lots of scope
are you just planning on using it as a sun shade or should i say rain shelter or are you planning to get side and a front to make it into a room?
81 MK2 motorhome
93 county 4x4
98 hi cube jumbo smiley td
00 flat bed smiley td
90 mk4 esc rs turbo
91 mk5 esc rs turbo
00 Mondeo st24 estate td
02 fiesta XRV td
Jambofive
Postby matt86_wd2 » Sun Jan 26, 2014 10:53 am
at 1st it will be just a sun shade but in the end i will get the sides for it , but untill then i will band a windbreak or 2 up !
i found the cheapest price is £405
http://www.johnscross.co.uk/products/fi ... wning.html
all the bits to go with it seems cheapest from here including the brackets and tie down kit .
matt
matt86_wd2
Postby Jambofive » Sun Jan 26, 2014 11:19 am
I have sides and a front for mine that's why I went for the zip model it's a lot more quicker and easier to put up and down because as the name suggests they just zip on and off . I was lucky I managed to find a set of sides and a front that were like new on gumtree for £300 . I know some ppl think these awnings are over priced but when you use one regular you realise they are very good value for money .
As for the price think there was sale on when i got mine cause am sure the rrp is £560 so Round £400 still a great price but that's just the regular f45s if u are serious aBout adding sides and front later I would pay the extra and get a zip one
Only a extra £60 pounds and as I said make life a lot easier that messing around with all those clip on bracket for the normal f45s
http://www.thefiammacentre.co.uk/magent ... -only.html
Trust me I spent months deciding on the right one even went and tried few of my mates different styles to see what suited
As I didn't want to spend my rare holiday times messing about with a awning .
81 MK2 motorhome
93 county 4x4
90 mk4 esc rs turbo
91 mk5 esc rs turbo
02 fiesta XRV td
Jambofive
