leemac wrote:is this a quick fix or replacement part???
motorwise wrote:leemac wrote:is this a quick fix or replacement part???
gearbox out - new concentric slave cylinder - also new clutch and flywheel (if it's a dual mass job anyway) should go in as well - false economy not to
good luck
Nighthawk wrote:motorwise wrote:leemac wrote:is this a quick fix or replacement part???
good luck
Thats right if it's a front wheel drive.
Rear wheel drive slave cylinders are external items and can be replaced in under an hour.
I really don't hold with the fit a flywheel everytime suggestions, there are set diagnostic checks that can be performed and if it passes those, it can go back and enjoy the rest of it's life.
Are you sure the dmf is rattling or is it transmission rattle?
incorrect countershaft preloading can bring on a rattle through the transmission at idle.
DMF's usually give a deep vibration through the vehicle.
Nighthawk wrote:FMC warranty policy and the prior approval process most dealers are bound to dictates that only correctly identified defective parts are repalced and that the vehicle is not over repaired.
Yes, some customers will request that they have a DMF fitted, but at around £250 +vat and and extra .6 hour labour it's not many.
