Robs Green Meanie !!!
Re: Robs Green Meanie !!!
Postby robbie.cee » Sun Feb 02, 2014 3:45 pm
Got a load of metpost spikes, bout 2 foot long are they any good?
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby limitedblack » Sun Feb 02, 2014 3:56 pm
Not in a strong wind :lol:
Happy Easter
limitedblack
Postby jonochap » Sun Feb 02, 2014 4:42 pm
Naw, you would be better of posting into concrete...
jonochap
Postby ake » Sun Feb 02, 2014 4:45 pm
jonochap wrote:Naw, you would be better of posting into concrete...
Definately
Postby James1123 » Sun Feb 02, 2014 7:07 pm
You can borrow my post hole digger, just go down about 2 foot or more!!!
2000 MK5 SWB Semi Hi-Top 76ps TDI
James1123
Postby jonochap » Sun Feb 02, 2014 8:47 pm
Plan plan plan robbie mate ;) trying to get 4 posts at 90 degrees to each other is no mean feat :)
jonochap
Postby James1123 » Sun Feb 02, 2014 9:29 pm
It's easy!!!!! Once you know how!!! :twisted:
James1123
Postby jonochap » Sun Feb 02, 2014 9:41 pm
:) yip
jonochap
Postby robbie.cee » Sun Feb 02, 2014 10:00 pm
No no no... lean to attached to house. Legs on one side only...
Big timber attached with expanding bolts to house horizontally, beams.off.of.that at right Angles.
Ill use joist hangers above the timber on wall to secure the stickyouty beams as well as them being screwed to the timber...
Legs only need to stop the other side dropping
I put a lot of thought imto the port itself.
Ground works the difficult bit for me
Had
MAKE IT FIT
robbie.cee
Postby jonochap » Sun Feb 02, 2014 10:17 pm
Mate, didnt mean to start anything off :) im sure you have :)
jonochap
Postby James1123 » Sun Feb 02, 2014 11:58 pm
Rob, I have the plans for my old mans gazebo, that would be all you want!!!
James1123
Postby James1123 » Mon Feb 03, 2014 9:31 am
Obviously with some side. I even have the spreadsheets with timber sizes and prices, including all fixings needed. I have a bracket that's better than a joist hanger :twisted:
James1123
Postby James1123 » Mon Feb 03, 2014 9:39 am
If we put the time in may even look like this!!!
James1123
Postby limitedblack » Mon Feb 03, 2014 6:20 pm
Rob, don't waste time, put a proper slab down that you can work on. Anything that you can't safely put an axel stand on isn't worth it.
Happy Easter
limitedblack
Postby James1123 » Mon Feb 03, 2014 8:40 pm
Of course a proper base is going in lim, rob loves digging holes!!!
James1123
