heater matrix pipes?
Postby belly » Fri Feb 16, 2007 10:28 pm
cleaning my van this afty i did a quick wash around the engine bay and check around , i noticed the two water pipes that go into the heater matrix have a clip missing :? the one that attaches to the black airbox above the rocker top area o/s , so one of the hoses has been rubbing on the engine and has worn a weak point in it :roll: ok fine i will buy a new hose and clip from the stealers tomoz but how do those pipes come off ? i noticed a traditional jubilee at one end but at the matrix end it looks like a special fitting maybe a push fitting is that correct ? and if i do it is the coolant system a pressurised system like a lot of froggy stuff ie having to bleed lots ? or just top up and run? cheers :D oh yeh its a fwd mk6 :wink:
belly
Kaiser Chief
Postby Nighthawk » Sat Feb 17, 2007 1:06 am
if your changing the pipe, don't worry about trying to undo the quick release clip on the end. Get a small pair of wire cutters and snip the thin black bars out if it and pull the pipe off.
you'll be left with the white clip still on the metal pipe, you can pull that off easily.
The correct way to remove them involves a special tool and twisting the white section 90 degrees.
Transit.........Job done
Nighthawk
Postby belly » Sat Feb 17, 2007 9:26 pm
thanks i will give it some persuasion with the snips :twisted:
belly
Kaiser Chief
Postby belly » Mon Feb 19, 2007 7:37 pm
ive bought the hose today :D but will i need to bleed the coolant system? or ca i just fit it and top up the level ? :)
belly
Kaiser Chief
Postby Nighthawk » Mon Feb 19, 2007 11:51 pm
Nah, fill it slowly and squeeze random hoses with bends in them and it should be ok.
Once all the coolant is in, give it a drive and the degas circuit will remove any air after the stat has opened.
I'n an ideal world, you'd pull a vacuum in the system and allow it's dissapation to draw the coolant in.
Nighthawk
Postby belly » Tue Feb 20, 2007 7:43 pm
thanks again i shall get on and change it tomoz :? ive got a nice henry vaccum :lol:
belly
Kaiser Chief
Postby motorwise » Tue Feb 20, 2007 11:07 pm
belly wrote:thanks again i shall get on and change it tomoz :? ive got a nice henry vaccum :lol:
hope you were joking about Henry - wouldn't want to see him drown :D
http://www.motorwise.net
motorwise
Postby Nighthawk » Tue Feb 20, 2007 11:17 pm
sod henry
I want to see what belly's hair looks like after Henry has drunk 13Lts of coolant
:D
Nighthawk
Postby motorwise » Tue Feb 20, 2007 11:18 pm
Nighthawk wrote:sod henry
:D
you're right - me too :lol: :lol: :lol:
motorwise
Postby belly » Thu Feb 22, 2007 1:03 pm
yeh only joking about henry :lol: trusty bit of kit tho has sucked plenty of rubble/sand/paste and still does the house :D unlike a crappy see thru fancy no suction loss thing :lol:
belly
Kaiser Chief
Postby belly » Mon Feb 26, 2007 6:44 pm
just a quick thanks to nighthawk, legend as always 8) fitted pipe exactly as he said :D a doddle no probs
belly
Kaiser Chief
Postby Nighthawk » Tue Feb 27, 2007 10:46 pm
8)
Nighthawk
Users browsing this forum: Google [Bot], Google Adsense [Bot], Moonscross
