external gas bottle idea ...
Re: external gas bottle idea ...
Postby RODAT » Thu Feb 13, 2014 4:06 pm
Not too sure on regs but think it has to be steel?Although Ive seen supposedly DVLA passed campers with wood bottle cupboards!
RODAT
Postby matt86_wd2 » Thu Feb 13, 2014 6:46 pm
nope they do not even say you need a gas box .
This has been covered so many times and from what your thinking is probally the regs if you want to have a lpg cert done on the van , which you dont need to register as a motorcaravan with the dvla .
matt
matt86_wd2
Postby ake » Thu Feb 13, 2014 6:50 pm
RODAT wrote:Not too sure on regs but think it has to be steel?Although Ive seen supposedly DVLA passed campers with wood bottle cupboards!
Timber is fine, but it should be sealed from the habitation area, and ideally only accessible from outside. It must have drop holes in the base for ventilation of leaked gas.
Postby matt86_wd2 » Thu Feb 13, 2014 7:08 pm
it wont be able to be accessed from outside and where it is located the arch is in the way but yet drop out vents will be there and all other joints have drop out vents nearby too
matt
matt86_wd2
