Have I got a special sqid then
Ive plugged the cruise wires into the bottom one. Is that right?
loot34 wrote:Mk7newbie
No you need the bcm ending in c- then the steering wheel, then you need to check that you have the wires going from the column end of the squib to the bcm, if you don't you need to make some up, after that you need modified software programmed in so you can have cruise enabled.
mk7newbie wrote:loot34 wrote:Mk7newbie
If I've got auto lights,wipers and heated seat do you reckon it would have the higher end bcm and if I have then vantuner should be able to program that and outside temp?
Rumble bee wrote:Squid is factory as far I know, im the second owner and can't see the AA fiddling with it![]()
So I need to split the second connector that ive plugged into the bottom one. And insert it into the top connector.
loot34 wrote:The part number will probably be on the underside, 4 tiny torque screws on the top
loot34 wrote:mk7newbie wrote:loot34 wrote:Mk7newbie
Yes, if you have all that then 99% you'll have the wiring, as did vantuner, fit the steering wheel, clocks, indicator and temp and martyn will program it all to work.
As i said the steering wheel will be plug and play in terms of wiring.
loot34 wrote:He's probably done it now![]()
Soprano it is very simple, Chris has a 1 off squib.
When you take the airbag of yours you'll see the black and brown wires, so remember where they go on the new 1 as they are for the horn the same as yours.
The new wheel connector with buttons is plug and play and so is the airbag connector.
Users browsing this forum: Google Adsense [Bot], gt_addict
