My Essex V6 Transplant
Postby Leeday » Wed Feb 19, 2014 9:19 pm
Hi all.
Well after a long time pondering (see topic viewtopic.php?f=4&t=130056 ) have decided to replace my 2.0 pinto with 4 speed auto box to Essex V6 connected to MT75 5 speed manual.
Hopefully now have all the parts required (few small bits still needed and am searching E-Bay etc continuously).
Will be starting the transplant on Saturday 8th March and given myself 1 week to do everything (as I will be doing it all alone..... even my missus is going away, "so I can get on with it" she says :shock: )
Will be posting photos on this thread of the project which will also involve fitting power steering, new front suspension, de-greasing and cleaning the engine bay etc.
Thanks to dieselhead123 for advice and supply of many parts.
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Re: My Essex V6 Transplant
Postby BROWNYS V6 » Wed Feb 19, 2014 11:39 pm
good luck wiv it lee,dont forget ya camera, plenty of pics :wink:
BROWNYS V6
Postby transitandy » Thu Feb 20, 2014 10:44 am
Goodluck m8 :)
Im looking forward to reading the thread of your work 8)
Postby thegreathowardo » Mon Feb 24, 2014 9:16 pm
Are you sure you don't want to go for a Rover V8 instead????
thegreathowardo
Postby Leeday » Mon Feb 24, 2014 9:26 pm
thegreathowardo wrote:Are you sure you don't want to go for a Rover V8 instead????
That was in the thought process and I was toying with the idea, but couldn`t find a suitable rover v8 donor engine and the Essex V6 has all the components available to make the swap more straight forward :D
I suppose you will now tell me you have a rover v8 engine for sale :roll:
Leeday
Postby Leeday » Mon Mar 10, 2014 1:36 am
Well, started on the conversion, today preparing to remove 2.0 Pinto and auto-box in one lump
Took all day removing all attachments.... exhaust took over an hour to remove (when I fitted it last year I meant it to be secure), auto cooler pipes were a pain, but now engine and box are ready to be lifted out in the morning, just sat on its engine mounts and an axle stand under the gearbox.
Have modified the mk5 power steering bracket so it bolts direct to the engine and not on an adaptor plate:
And The Essex V6 waiting to be worked on and installed:
Leeday
Postby robbie.cee » Mon Mar 10, 2014 7:51 am
Lovely motor thRe.think i encounter every possible problem on way in my van But Overcome all so If any problems i can probably help lol.
Check timing not retarded !!! Or red Hot manifolds ensue!
Loads or torque, great sound too! Enjoy!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Leeday » Mon Mar 10, 2014 9:41 am
8) Cheers Robbie 8)
Leeday
Postby Leeday » Mon Mar 10, 2014 1:51 pm
Finally lift the engine / gearbox out:
Due to the driveway sloping uphill into the garage and being on my own and the weight of the engine / gearbox combined had to use my 12 volt winch with homemade towbar support and the garage back door frame :D
But at last the engine and gearbox are out and safely in the garage with no incidents:
Now to start cleaning the engine bay and fitting the mk5 power steering rack, new springs and shockers, new mk3 track rod ends and new lower ball joints....... now where`s my coffee :D
Leeday
Postby whitemice » Mon Mar 10, 2014 4:01 pm
Skill 8)
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby Leeday » Mon Mar 10, 2014 7:06 pm
Slow progress this afternoon... painted engine bay with GUNK and sprayed it off, painted it again with GUNK sprayed it off..... 26 years of oil, grease and dirt so slow progress.
Thought whilst waiting for the GUNK to soak in would remove the manual steering rack :shock: Got drivers side nut undone and separated the ball joint with a splitter, came to the passenger side, couldn`t even get nut undone, spent about 40 minutes with the 22mm spanner and a lump hammer, then switching to the 21 mm spanner and the lump hammer and finally removed the nut, however cannot separate the ball joint, am using a 18 inch fork ball joint splitter and lump hammer and gallons of WD40 but the joint will not split, so after an hour of trying to split the joint I have given up for today, need food and some beer :D will attack the track rod end again tomorrow.
Leeday
Postby dieselhead123 » Mon Mar 10, 2014 8:34 pm
Hi mate, good to see you are getting on well with this, done well for working alone 8)
Sent you a PM regarding the pulley situation.
Postby transitandy » Mon Mar 10, 2014 10:48 pm
Coming along nicely lee :)
Postby Leeday » Tue Mar 11, 2014 11:59 am
Well, went out this morning to attack the passenger side track rod end ball joint which is one of the most defiant ball joints I have known:
So after 30 minutes of hammering, bashing and swearing :lol: decided heat was needed, but alas cannot find my portable blow lamp, so decided to use my trusty old Bosch heat gun, after 10 minutes of blowing hot air on the thing and one final swing of the lump hammer .. pop .. the joint separated:
A wave of happiness and joy flowed through me :lol: well thought thank f*** for that.
Manual steering rack now removed and can at last progress:
Leeday
Postby whitemice » Tue Mar 11, 2014 1:59 pm
WM: Smell that? You smell that?
Leeday: What?
WM: V6 running, son. Nothing else in the world smells like that.
[kneels]
WM: I love the smell of V6's in the morning. You know, one time we had a garage swap, for weeks. When it was all over, I walked up. We didn't find one of 'em, not one stinkin' bolt missing. The smell, you know that gasoline smell, the whole drive. Smelled like
[sniffing, pondering]
WM: victory. Someday this swap's gonna end...
[suddenly walks off]
whitemice
