NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby tez » Thu Mar 06, 2014 2:11 am
wots with the sun visor or what ever it is :lol:
tez
Postby paul2012 » Thu Mar 06, 2014 2:51 am
tez wrote:wots with the sun visor or what ever it is :lol:
You mean this cover :?:
It's for compartment where jack etc is stored :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Milemuncher » Thu Mar 06, 2014 8:27 am
I think it actually looks more like a Connect shape if you drew some wheels on it !
Milemuncher
Postby tez » Thu Mar 06, 2014 12:31 pm
thanks u both new there be a simple answer :D
tez
Postby Milemuncher » Thu Mar 06, 2014 6:56 pm
The cover was well under a fiver to buy. Just to tidy up a hole really, as the jack is screwed into the panel behind the driver seat (in a felt bag)
Milemuncher
Postby ishmail » Thu Mar 06, 2014 8:44 pm
Milemuncher wrote:The cover was well under a fiver to buy. Just to tidy up a hole really, as the jack is screwed into the panel behind the driver seat (in a felt bag)
yep same as mine to :)
ishmail
Postby paul2012 » Wed Mar 12, 2014 9:50 pm
Finally :!: :!:
Bagged a pair of Door cards in dark pewter :mrgreen:
Old ones will be up for grabs..
Also done Mondeo/Focus mk3 flip key. Already had the remote fob but had a flat key blade.
Purchased blank Tibbe Key blade from ebay then added WI carbon chip in casing as it wasn't supplied with one.
Then got Ford to cut blade at the same time while cutting a new Standard key for me. 8)
Genuine Ford standard key with W1 carbon chip - Ford part no F4355661 £20. (uncoded)
paul2012
Postby paul2012 » Mon Mar 17, 2014 12:55 am
Changed stereo head unit today.
Fitted a Sony Gen 2
paul2012
Postby paul2012 » Fri Mar 21, 2014 9:09 pm
Purchase this tow bar from ebay £55 complete with fitting kit - remove from a connect.
Strange looking fitting kit - 2 long bolts & 4 spacers :shock:
Oh well, 4 new bolts are required - preferably the correct ones :!:
paul2012
Postby gt_addict » Fri Mar 21, 2014 11:44 pm
£55?! I only paid £70 for my second hand witter one with everything included (bolts, instructions, electrics).
gt_addict
Postby paul2012 » Sat Mar 22, 2014 1:14 am
gt_addict wrote:£55?! I only paid £70 for my second hand witter one with everything included (bolts, instructions, electrics).
I grabbed this one as it was listed with elec & fitting kit.
Although fitting kit or part of, is not even correct for connects :roll:
As for electrics there's no by-pass relay :( Which is a definite must have.
paul2012
Postby paul2012 » Sat Mar 22, 2014 5:47 pm
Finally picked door handles up today.
Fitted rear handle first - it's the easiest one. No need to remove door lock assembly (unlike the fronts doors)
As for the old door handles. Like this rear one, they are badly faded.
I still have paint left (Diamond White). So may decide to get them painted up too & put them up for sale ??
paul2012
Postby paul2012 » Mon Mar 24, 2014 9:48 pm
Fitted front door handles & here is the procedure :wink:
Once door card has been removed. Drill out 2 rivets in security cover.
Unbolt & remove window runner rail
Remove 3 torx bolts securing door lock assembly, Key barrel clamp & linkage to door handle.
To remove key barrel, insert key & turn until square locking tab depresses. Rotate barrel clockwise then pull it free from door.
Remove torx bolt securing door handle end cap (small part), then pull & slide main handle from door.
also remove rubber seals - I did this to clean them & door.
Then refit handles the same way they were remove - make sure handle engages with lever on reinforcement panel.
Refit security cover with new rivets
Before fitting my door cards, I'm going to fit Mondeo mk3 interior door handles 8)
paul2012
Postby ishmail » Mon Mar 24, 2014 10:11 pm
Image[/quote]
could you show that on the picture how is done please as i want them to but when i look at that mondeo one middle hole is bigger then connect ones :?:
ishmail
Postby paul2012 » Mon Mar 24, 2014 11:09 pm
ishmail wrote:could you show that on the picture how is done please as i want them to but when i look at that mondeo one middle hole is bigger then connect ones :?:
Remove the bottom end on pin first (there is what appears to be a pressed on cap) from both Connect & Mondeo interior door handles.
Once pin has been removed you can then remove connects handles & fit Mondeo ones in place of the Connects ones.
Refit pin, there should be enough pin protruding from the bottom - carefully bevel edge over with a hammer.
They should look like this once you have finished
:wink: 8)
paul2012
