all you will need is an Essex V6 with Transit engine mounts
bobdragon12 wrote:Leeday wrote:Found a scrap yard today which had a mk4 2.5 diesel tipper transit in it (mwb I think) , so removed from it prop front bearing mount that bolts to chassis, throttle cable, power steering reservoir mount bracket, clutch pedal return spring and all that cost me ... £5.00WOW loving that scrap yard:
Which scrap yard had the tipper , need a couple of bits
mealic wrote:Hi Lee.
A mate of mine lives in Niton over there and comes over to Haywards Heath area at the start of every month. I`m sure he would bring you any bits back if you couldn`t get them delivered.They can always be dropped at mine,
ali
bobdragon12 wrote:Firstly ,if you need a hoist give me a shout , second are you 100% sure the arm was locked into the pin properly , third was the cable tensioned up ? They may sound silly but I have to ask
