Lowering the new Transit custom?
Re: Lowering the new Transit custom?
Postby belly » Sat Mar 22, 2014 6:38 pm
Goliath wrote:bumping this thread a bit..
Still no bolt on loweringkit to buy somewere?
Speak to LimitedBlack as he had his rear springs re profiled on his Mk7 Taxi :wink: He posted a thread about it :D
belly
Kaiser Chief
Postby Benjamin08 » Sat Mar 22, 2014 7:08 pm
A guy here in France did it by decambring sping. See here :
http://ford-transit.forumactif.com/t100 ... -van-155cv
Benjamin08
Postby Alar » Sun Mar 23, 2014 4:16 pm
Dont lower it mechanically, do it visually. I added sidebars and it looks much lower now. I have a lwb, so I dont have that "ass up in the air" issue as swb models
125ps 310LWB Trend Powerty Edition
Alar
Postby Clarkrally » Sun Mar 23, 2014 5:18 pm
Does no one do a full air suspension kit for these vans yet? Such as VB air suspension.
Clarkrally
Postby Goliath » Mon Mar 24, 2014 4:06 pm
Clarkrally wrote:Does no one do a full air suspension kit for these vans yet? Such as VB air suspension.
That would be awesome!
all i find is this...
http://www.driveriteair.com/catalog/sea ... earch=true
but i cant find anyone that sells these kits...
Goliath
Postby Goliath » Mon Mar 24, 2014 4:07 pm
Benjamin08 wrote:A guy here in France did it by decambring sping. See here :
cant see the pics, i need to be logged in it says..
Goliath
Postby Benjamin08 » Tue Mar 25, 2014 7:28 pm
Yes you have to create an account.
Benjamin08
Postby ThundAh » Tue Mar 25, 2014 11:08 pm
DrDeAtH wrote:Decambering the springs is the SAFEST way to do it.
Although why you would bother in a van that you load up with weight is beyond me.
Best to go with an air suspension setup anyway. At least you can adjust the ride height.
Definitely. It sounds insane to spend so much on a brand new van just to cripple it
.___my tranny___.
Mk5 SWB Low roof
2L DOHC - ULP - Built December 1998
Brand new clutch, breaks and drums installed by ford 2012
building into mini camper as of 2014
ThundAh
Postby Hypper » Sat Apr 05, 2014 2:07 pm
Hope some one... Can help... On this matter
How can you bent a leaf spring... I am reddy to try something...
Med venlig hilsen / Best Regards
Claus Sørensen
Ford transit custom black - '14
Upgrade: speakers 200mm, Shark antanna, Led front cab, HID front lights, Chip tun in ECU,
Bike: Canyon Nerve AL 7.9
www.Waftb.com
Hypper
Postby Goliath » Tue Apr 08, 2014 3:04 pm
Benjamin08 wrote:Yes you have to create an account.
i have an account, still dont work. can you maybe upload the pics here?
Goliath
Postby RussC73 » Fri Apr 11, 2014 1:56 pm
I would leave the rear and concentrate on lowering the front, simple coil over struts should do it.
RussC73
Postby Benjamin08 » Fri Apr 11, 2014 7:25 pm
Here it is :
BEFORE LOWERING
AFTER LOWERING
Benjamin08
Postby RussC73 » Sat Apr 12, 2014 7:02 pm
I would lower the front, when you are carrying weight the rear will naturally lower... after all its a van and its supposed to carry a little weight :D
Anyone lowered just the front ?
RussC73
Postby Goliath » Sun Apr 13, 2014 12:16 pm
RussC73 wrote:I would leave the rear and concentrate on lowering the front, simple coil over struts should do it.
do you know were i can buy coilovers?
Goliath
Postby Hypper » Fri Apr 25, 2014 9:10 am
Photo of the rear axel
Front
Claus Sørensen
www.Waftb.com
Hypper
Return to Transit Custom
