Mk2 Kingpins. Any short cuts?
Re: Mk2 Kingpins. Any short cuts?
Postby swear_bear » Thu Apr 03, 2014 9:46 am
Is there an easy way of checking if the thrust bearings are as bad as all that?
will the steering behave a certain way, like being sluggish or something?
would unscrweing the greasecap and checking that way work?
I lift the wheels and check the gap today before trying to grease them.
Rotten MK2 camper built from a pickup almost 30 years ago, soon becoming a pickup until i get the materials to rebuild the camper part again.
swear_bear
Postby baconsdozen » Fri Apr 04, 2014 10:34 am
Clean it all down so you can see. Then jack the vehicle up so that the wheels hang free (better still take them off).Using a long bar as a lever try and lift the stub assembly vertically. There should only be a very small movement up and down.
baconsdozen
Postby Vegard » Mon Nov 15, 2021 11:29 am
mb4ever wrote:
baconsdozen wrote:Despite the fact that one of the thrust bearings was quite badly damaged and the other wasn't that far behind I was a bit disappointed on my test run.The steering isn't much lighter and I was hard pushed to notice any difference in self centering or what ever.
Bugger.
Have you checked: -
.........................Castor?
.........................Toe in?
Did you grease it with the weight on?
As well as with the weight off?
Urban myth I expect.
How are you supposed to adjust caster on a MK1/2 Transit?
Vegard
Postby dumper » Mon Nov 15, 2021 3:20 pm
You don’t it’s fixed from manufacture the only adjustment is the tracking.
Postby Vegard » Wed Nov 17, 2021 4:48 am
My thoughts exactly. I guess you could tilt the cross member in some way :D
Vegard
Postby Vegard » Mon Dec 27, 2021 7:48 pm
Just did it :)
https://www.facebook.com/100054307339221/posts/447462323740675/?d=n
Vegard
Postby Muttley » Tue Dec 28, 2021 10:21 pm
Why?
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby Vegard » Mon Jan 10, 2022 1:03 am
dumper wrote:You don’t it’s fixed from manufacture the only adjustment is the tracking.
Just foind out. There’s a small wedge between the spring and beam. That could easily be modified :)
Vegard
Postby dumper » Mon Jan 10, 2022 8:01 am
I think that is just a spacer to lift the ride hight on Diesel vans not sure if they fitted it to the later Petrol vans all they do is slightly increase the ride hight due to the extra weight of the York / DI engine I cannot remember if they fitted them on the Perkins in the mk 1 .
Postby Vegard » Mon Jan 10, 2022 9:08 am
dumper wrote:I think that is just a spacer to lift the ride hight on Diesel vans not sure if they fitted it to the later Petrol vans all they do is slightly increase the ride hight due to the extra weight of the York / DI engine I cannot remember if they fitted them on the Perkins in the mk 1 .
There's a spacer and a small wedge. I'll get a picture.
Vegard
Postby dumper » Mon Jan 10, 2022 11:52 am
Yes but it’s a solid beam axle the only way to change anything but the tracking is to bend the beam or stub axle
Postby Vegard » Mon Jan 10, 2022 2:50 pm
dumper wrote:Yes but it’s a solid beam axle the only way to change anything but the tracking is to bend the beam or stub axle
No, not caster.
Vegard
Postby dumper » Mon Jan 10, 2022 5:24 pm
But why would you want to adjust the caster only advantage maybe more or less self Centreing
Postby Muttley » Mon Jan 10, 2022 10:25 pm
What is the result you desire? The wedge on the axle is for Caster angle, why change it?
Muttley
Postby Vegard » Fri Jan 14, 2022 12:11 pm
I have no desire to do so, I'm just saying it's easy to do so if wanted.
Vegard
Return to Mk 1 & 2
