How to clean turbo?
How to clean turbo?
Postby Chris205 » Fri Apr 04, 2014 10:04 pm
Been having some issues with with over and underboosting, before I go throwing money at it just wondering how you would go about cleaning the turbo of a mk7 140 rwd, would something like a fortes cleaner do the job?
Chris205
Re: How to clean turbo?
Postby stephenferguson » Fri Apr 04, 2014 11:51 pm
Terracleans are supposed to. Not 100%, there are mixed reviews about this service.
Best way would be to take off and clean it.
2008, VW Transporter T5, T30, 6 Speed 130, Reflex Silver.
2006, 100 T280, MWB, Mid Roof, Moondust Silver. SOLD
Mk6-Mk7 Facelift Photos Here
stephenferguson
Postby Chris205 » Sat Apr 05, 2014 7:58 am
There is some severe corrosion on the manifold bolts I could see it turning bad, mite just start wd40ing for a few weeks then give it ago haha
Chris205
Postby tibsy » Sat Apr 05, 2014 9:58 am
forget wd40, get some "plusgas"!
mk7,60 plate,2.4-115ps-hirf lwb rwd
The words of the Prophet`s are written on the subway walls
tibsy
Postby v8dave » Sat Apr 05, 2014 10:08 am
Get new studs/nuts/bolts etc from ford, their not too expensive and make putting everything back together easy.
v8dave
Postby Chris205 » Sat Apr 05, 2014 11:50 am
I really don't know if they will come off whiteout grinding or something extreme van before I bought it looks like it was sat for a good while, it's a 2010 but engine looks like it's come off titanic, I've never attempted to take a turbo off anything let alone one so rusty, is there anything I should be careful of whilst doing it?
Chris205
Postby limitedblack » Sat Apr 05, 2014 2:05 pm
Doubt if cleaning the turbo will do much, if something is seized, and then cleaning won't do anything. I rebuilt my turbo, all the nuts came off the manifold easy apart from getting to them. Is it a black box actuator turbo, if so these do fail and give varying boost problems.
Happy Easter
limitedblack
Postby loot » Sat Apr 05, 2014 5:48 pm
I think it's a map issue.
You can undo the bar that joins the actuator to vnt via a circlip, then you can see if the vnt moves freely, don't force the actuator tho as it is a geared servo
07 350 170ps
Ids map here
loot
Postby Chris205 » Sat Apr 05, 2014 7:48 pm
Limited my best guess from everything I've read is that the vanes mite be stuck open? And mines a 140 with an electronic actuator
Chris205
Postby Chris205 » Sat Apr 05, 2014 7:51 pm
So is that more likely to have gone than the turbo vanes seized?
Chris205
Postby loot » Sat Apr 05, 2014 8:02 pm
You could just watch the actuator and get someone to floor the gas pedal a few times.
07 350 170ps
Ids map here
loot
Postby Chris205 » Sat Apr 05, 2014 8:06 pm
What should it look like if it's working correctly?
Chris205
Postby loot » Sat Apr 05, 2014 8:10 pm
It should move lol, look at the black box (actuator) and feel the rod behind it, that will move roughly a cm on hard acceleration(full movement).
If it grinds etc and no movement then it's is probably at fault.
If you get the van on ids you can read live data and do a turbo test also.
07 350 170ps
Ids map here
loot
Postby Chris205 » Sat Apr 05, 2014 8:22 pm
Defo the electronic actuator should move so much? I know the vacuum one on my 110 did
Chris205
Postby loot » Sat Apr 05, 2014 8:39 pm
I never measured tbh but you can undo the metal linking rod and move the arm on the turbo vnt, it'll move up and down with stop at either end, you could have a faulty vnt inside the turbo but how can you have over boost and under boost at the same time?
I think you would be best getting it on ids
07 350 170ps
Ids map here
loot
