How to clean turbo?
Re: How to clean turbo?
Postby Chris205 » Sat Apr 05, 2014 8:42 pm
Yeh probly will do the cleaning the turbo was a long shot I guess I'll get it plugged in an post the findings
Chris205
Postby limitedblack » Sat Apr 05, 2014 8:47 pm
It's all setup on a jig, but pop off the circlip and move the actuator rod. It should feel really loose and move easy. Those electronic actuator boxes are known to fail.
Happy Easter
limitedblack
Postby Chris205 » Wed Apr 09, 2014 11:14 am
Just had a lad rev van up while I look at the actuator it is moving up and down does seem to have a jerk on it rather than smoothly up, is that normal? I would try taking the circlip off but I've got the touch of a rapist
Chris205
Postby loot » Wed Apr 09, 2014 11:27 am
Chris205 wrote:Just had a lad rev van up while I look at the actuator it is moving up and down does seem to have a jerk on it rather than smoothly up, is that normal? I would try taking the circlip off but I've got the touch of a rapist
:shock: i found him quite gentle :o
Make sure the arm isn't catching on rust first, we had 1 that failed the turbo test:-(
Maybe spray some wd on the actuator linkage to prove it isn't that which is sticky.
You do need to remove the checkup to check the vnt, next is the actuator, ids diagnostic turbo test will be best i think.
07 350 170ps
Ids map here
loot
Postby Chris205 » Wed Apr 09, 2014 1:23 pm
Linkage seems pretty free, it's a working van so I'm literally lookin at it on my dinner, seems a lot of people have had the same symptoms problem is as soon as they've solved it they don't post the solution!! So I just read symptoms but no cure selfish if you ask me
Chris205
Postby loot » Wed Apr 09, 2014 2:39 pm
I know, we slave away to help and the ingrates don't give feedback :? I'm working on a remote detonator for just such occasions :lol:
07 350 170ps
Ids map here
loot
Postby Chris205 » Wed Apr 09, 2014 4:13 pm
Well I'm working garage next week so while I'm working he's going to have a look I'll be sure to post the solution to my problem, just another little thing I've noticed, at first when I start the van some times it sounds like a whooshing noise and the van drives fine while this is happening, like it's sucking in more air??
Chris205
Postby limitedblack » Wed Apr 09, 2014 4:57 pm
Belly had over/under boost error codes and it was the electronic actuator. As stated earlier, if the VNT is moving freely (you will need to take that circlip off), then likely to be actuator....
Happy Easter
limitedblack
Postby Chris205 » Wed Apr 09, 2014 5:38 pm
Do I take off the bottom circlip or top one? Where's a Chinese kid when ya need one
Chris205
Postby loot » Wed Apr 09, 2014 5:44 pm
It won't matter as long as you separate them to allow you to move the vnt although you are probably best to undo that 1.
07 350 170ps
Ids map here
loot
Postby Chris205 » Wed Apr 09, 2014 5:47 pm
Just had a look no way of getting to bottom one really,, is the top clip a circlip or like a push fitting clip?
Chris205
Postby loot » Wed Apr 09, 2014 5:49 pm
Should be back to front circlips, maybe get it with a small flat blade screwdriver, it is fiddly :-(
07 350 170ps
Ids map here
loot
Postby Chris205 » Wed Apr 09, 2014 5:58 pm
If say neigh on impossible, can't even see the clip just trying to feel for it, can you point me to a picture or diagram of it so I can get an idea of what I'm feeling
Chris205
Postby loot » Wed Apr 09, 2014 6:47 pm
Don't have any sorry, could check ebay?, it may be possible to undo the 3 10 mm bolts that hold the actuator back plate on but you may end up getting angry and smashing the place up lol
07 350 170ps
Ids map here
loot
Postby Chris205 » Wed Apr 09, 2014 6:50 pm
Yeh I've checked ebay and web can't seem to find a pic, I'm goin to get my mate round with his van to see how smoothly his moves, I've had my tee now so mite give it another go
Chris205
Users browsing this forum: Sports140
