stephenferguson wrote:Cracking thread mate
Foneman wrote:Keep up the good work
ishmail wrote:i Hate you lol Making my 2006 van look sh*t next to your 03 Reg
paul2012 wrote:ishmail wrote:i Hate you lol Making my 2006 van look sh*t next to your 03 Reg
Current project is a 53 reg...
Did you mean my previous project - 2003 (03 reg) Connect![]()
Project thread hereviewtopic.php?f=54&t=116284&hilit
markspark71 wrote:Have you done a total cost of the project to date ?
paul2012 wrote:Did some a couple of experiments trying to enable optional features on GEM modules fitted to 2009 onwards connects.![]()
When using IDS the only features available to enable/disable are remote unlocking single step or double step & Heated front screen.
There are no options available to enable/disable the optional features - automatic wipers / automatic headlamps (Autowipe/lights) or Alarm.
I have 3 GEM modules as show below
All 3 modules have the same standards features enabled.
Apart from the optional features which differ & are as follows :-
GEM A - Heated front screen
GEM B - Heated front screen & Autowipe/lights.
GEM C - Heated front screen & Alarm
As I want Autowipe/lights & alarm for my connect. Fitted GEM B ran IDS, selected PMI (Programmable Module installation) DATA was downloaded from module.
IDS instructed to fit new module, fitted GEM C & DATA was uploaded to it.
Outcome GEM C has Autowipe/lights has been enabled but Alarm had been disabled![]()
Next step was reprogram GEM C, Unplugged it & ran IDS (new session) & selected PMI again for GEM. IDS instructs to install new module, GEM C was plugged back in. IDS then gave option to program "As Built Data" to proceed with this It verifies vehicle Vin number too download correct calibration for that Vin from Ford.
When IDS ask to confirm if Vin nunmber is correct select NO, & enter in Vin number from another connect that has the features already enabled. Calibration is downloaded for new Vin & uploaded to GEM C.
Outcome - Now GEM C has Autowipe/lights & Alarm enabled![]()
To change Vin number back to original, start a new session in IDS while GEM C is still plugged in & select PMI. when is asks to comfirm vin is correct select no & enter in your original vin number. Data is then downloaded from GEM C. When prompted to install new module, leave GEM C plugged in & DATA is re-uploaded too it with your original Vin Number.
Outcome - GEM C still has Autowipe/lights & Alarm enabled![]()
Extra wiring for Alarm feature, consists of 1 wire for alarm horn & 1 wire for bonnet switch![]()
Alarm horn is location behind glovebox see below
nardi wrote:paul2012 wrote:
Hi Paul you are doing a great job in here and don't worry what other people saying .
I was curious if I wanted to add alarm on my 2010 connect ,what kit should I need except alarm horn and bonnet switch you showed on here because the wiring is already there. Who can reprogram the existing CL/RC module?
nardi wrote:Thanks Paul,but I am in London ,a bit too far from you.
Can you point me what module required?
nardi wrote:You are great Paul
I will keep an eye on ebay for a gem module with alarm but I noticed that there are no switches on the front doors,how the lights come on when you open a door?
