didn't get much more than that done today having learned that a good friend of mine had passed away this morning so wasn't really in the mood to work
karl mcghee wrote:Coming on now mate epic work I have it all to come
Restorationvanman wrote:karl mcghee wrote:Coming on now mate epic work I have it all to come
You certainly have![]()
the best bit of advice I could give you (looking at the extent of the work you'll need to do) is to get hold of a cheap laser (around £20) and set this up at the rear of the chassis (stand it on something fixed across the 2 rearmost "bed" brackets) so that it fires a horizontal line across the rear of the cab, mark the line on the cab with a marker pen, this will give you a "reference point" at the start and as you do the repairs keep checking that the laser is still aligned with the pen mark (it WILL move off the line as you do the repairs, welding on the bottom will pull it down as it cools and obviously welding on the top will pull it up) If it moves "too far" ie over 3mm (that's about the tolerance ford worked to when they made it according to the book with chassis plans/dimensions I have...Genuine ford publication) do a few "dummy" weld runs opposite the repair to pull it back (unless the repair is thru the full height of the chassis in which case it should balance out) try not to do too much welding concentrated in the same area all at once, keep an eye out for any overall movement and compensate by welding elsewhere (opposite) to limit the distortion
I used this method when I re-attached the chassis to my truck and when finished I checked and double checked everything and its all within acceptable limits (less than 3mm over the length of the chassis) and a lot cheaper than having it on a "jig" for days, weeks (or in my case) months![]()
Of course I might have been too fussy but that's me all over....Just like things to be right(or at least as near as possible)
slowly but surely and all that.....cant wait to see some progress on yours![]()
That's a fantastic result ... brilliant to see someone doing a proper 'bottom up' job properly.Restorationvanman wrote:Hoofookingray the chassis is FINISHED![]()
....but....I forgot to take the camera
Work is what pays for it!Cant wait to start putting the axle/suspension back in but working for next 8 days so wont be done quick
ColinJack wrote:Work is what pays for it!Cant wait to start putting the axle/suspension back in but working for next 8 days so wont be done quick
Users browsing this forum: Vee4
