Pool of oil on top of engine around injectors
Postby dymondaudio » Mon May 19, 2014 8:06 am
56 (mk7) 2.4/100 lwb 350
There's a pool of oil that accumulates around the injectors, anyone else had the same or know what the problem is, i.e where it's leaking from?
2008 2.4 T350/140 Trend LWB H/R
2008 2.4 T350/115 LWB HR
2006 2.4 T350/100 LX LWB MR
2002 2.0 T280/75 MWB MR
2000 2.5 SWB MR
dymondaudio
Re: Pool of oil on top of engine around injectors
Postby blue estate » Mon May 19, 2014 8:16 am
The seals have gone in the rocker cover , you need new seals and new copper washers for the injectors
blue estate
Postby dymondaudio » Mon May 19, 2014 10:02 am
Nice one, thank you. I'll get a quote from my usual garage and go from there!
It doesn't sound expensive but that often means that it is !
2000 2.5 SWB MR
dymondaudio
Postby snowballer » Mon May 19, 2014 6:29 pm
easy diy job
snowballer
Postby dymondaudio » Mon May 19, 2014 6:36 pm
Ok are there any instructions/videos around?
2000 2.5 SWB MR
dymondaudio
Postby blue estate » Mon May 19, 2014 6:39 pm
dymondaudio wrote:Ok are there any instructions/videos around?
This is for the 2.2 but same principle http://www.youtube.com/watch?v=MdsEu3-9B0s
blue estate
Postby griffin41 » Sun May 24, 2015 12:34 am
can this cause any running problems by any chance - thanks :?:
that is not my belly - i just need to make that clear and if you find a cure let everyone know it
griffin41
Postby ake » Sun May 24, 2015 5:51 pm
griffin41 wrote:can this cause any running problems by any chance - thanks :?:
Yes it'll cause increased noise, reduced power and increased fuel consumption
