Mk1 LWB Ex-Feuerwehr Camper Conversion
Re: Mk1 LWB Ex-Feuerwehr Camper Conversion
Postby Muttley » Wed Apr 16, 2014 10:19 pm
What year is the axle?
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby Luke » Thu Apr 17, 2014 9:53 am
Muttley wrote:What year is the axle?
think its a 1994 :D
the 3/8 unf bolts are close they will bolt it up but either the thread i tried is worn or they are wrong
Postby Muttley » Thu Apr 17, 2014 10:30 pm
That will deffo be metric fine, I thought it was a mk1 axle :oops:
Muttley
Postby Luke » Thu Apr 17, 2014 11:29 pm
Muttley wrote:That will deffo be metric fine, I thought it was a mk1 axle :oops:
:lol: cheers
Postby Luke » Tue Jul 22, 2014 7:11 pm
all this hot weather is making me want this done - so i did a bit more today :D
fitted the LPG tank (this is for on board appliances not running the engine)
here it is :mrgreen:
nope its not to close to the ground its spot on :D for those who didnt read the thread when i got the tank 5 years ago its off a mk6 transit :D
Postby MinorMatt » Tue Jul 22, 2014 7:23 pm
You need a 4 hole one for a domestic take off don‘t you Luke?
I would think the 10 year inspection still applies?
Postby RustWidow » Tue Jul 22, 2014 7:29 pm
It looks a bit like a bomb under there, are you planning to launch an attack at billing? Lol
RustWidow
Postby Luke » Tue Jul 22, 2014 8:02 pm
MinorMatt wrote:You need a 4 hole one for a domestic take off don‘t you Luke?
no i can just cut the pipe short :D
Postby MinorMatt » Wed Jul 23, 2014 7:39 am
Are you sure Luke?
Autogas tanks supply the gas in the liquid phase to the engine - and domestic appliances need it in the gas phase
Postby Luke » Wed Jul 23, 2014 8:56 am
yeah but the 'gas' bottle still has liquid in it - we had a discussion when i 1st had the though viewtopic.php?f=58&t=34707 :D hope it works now anyway :lol:
Postby MinorMatt » Wed Jul 23, 2014 10:48 am
Thats correct...
But a gas bottle takes off the vapour at the top, whereas an LPG tank takes the fluid from the bottom!
Postby Luke » Wed Jul 23, 2014 12:59 pm
MinorMatt wrote:Thats correct...
yeah basically what i plan to do is convert the tank to pick up off the top by cutting off the pipe that goes to the bottom as the pipe is mounted at the top :D
i'm not 100% certain it will work but worth a try - it wont be for a while the main reason i mounted the tank is to get it out of the way so i can work on the interior :D
Postby Luke » Wed Jul 23, 2014 6:07 pm
had a look at the front today decided on the best way was a mk3 axle as i'm using mk3 pas box - the tre's are all different between mk1/2 and mk3 but i'm not 100% convinced you cant fit a mk3 box on a mk1/2 axle. i did want to use the mk1 beam as its very low millage but after inspecting the mk3 one its in good condition so i decided to go with that all mounted up to mk1 springs and shockers
all mk3 beam axles are 6 stud and i wanted 5 stud so i fitted mk1/2 hubs on the mk3 stud the only difference i can see is the nut and washer size the mk1/2 calipers bolt up to the mk3 beam mounts and are central to the disk
this is what it looks like - the mk3 4 pot calipers will bolt over but im not sure if the foul the hub face - thats something for later as ive got a pair spare :D
then the whole beam gets a coat of paint before fitting 8)
the old mint mk1 beam axle complete with hubs and brakes is for sale if anyones interested :mrgreen:
Postby RustWidow » Wed Jul 23, 2014 8:30 pm
Looks good
RustWidow
Postby ake » Wed Jul 23, 2014 9:00 pm
Steady on Luke, you'll finish it if your not careful :lol:
