NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby paul2012 » Mon Jul 28, 2014 12:06 am
After taking connect for a good run, No more leaks. Front suspension is indeed stiffer & now sticks to the road :D
Just a quick note, with gearbox being a ratio of 3.41. Engine speed when cruising at 60mph is approx 1700 rpm in 5th gear.
Improves fuel economy & engine is no longer racing away, plus it runs quieter 8)
- For the select few who may think "yeh right pull the other one." Watch this vid here :arrow: https://www.youtube.com/watch?v=ylsypW6ovxw :lol: :lol:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby mrtn » Mon Jul 28, 2014 3:40 pm
paul2012 wrote:Just a quick note, with gearbox being a ratio of 3.41. Engine speed when cruising at 60mph is approx 1700 rpm in 5th gear.
TDDi wouldn't survive it, I guess.
1.6 Ecoboost A/T LWB '16
mrtn
Postby paul2012 » Mon Jul 28, 2014 10:45 pm
You can fit a gearbox with a ratio of 3.56 from a 2000-2001 Focus TDDI (part no 1S4R-7002-LC) :wink:
paul2012
Postby mrtn » Mon Jul 28, 2014 10:46 pm
You never run out of ideas, do you?
mrtn
Postby 75psT330lwb » Mon Jul 28, 2014 10:56 pm
mrtn wrote:You never run out of ideas, do you?
:lol: :lol: :lol: :lol:
Custom Ecoblue
75psT330lwb
Postby paul2012 » Tue Jul 29, 2014 11:37 pm
Load of ideas 8)
When putting them to practical use, is where the fun begins :mrgreen:
paul2012
Postby paul2012 » Tue Aug 05, 2014 7:23 pm
Still waiting for new V5 to arrive :(
Silicone boost hoses, thinking of changing all turbo & intercooler hoses.
Anyone here know where I get a silicone one to replace main boost hose from Turbo (VNT) :?:
Must be for a 110ps as 75/90ps are different
paul2012
Postby jasonescortcozzie » Wed Aug 06, 2014 6:05 pm
I'm ordering green ones for mine from a Samco distributor same as the focus hoses as they don't list a kit for the connect.
jasonescortcozzie
Postby paul2012 » Wed Aug 13, 2014 1:10 am
jasonescortcozzie wrote:I'm ordering green ones for mine from a Samco distributor same as the focus hoses as they don't list a kit for the connect.
I can get the hose from inlet manifold to top pipe & 2 short hoses from top pipes to intercooler.
Still can't get the hose from VNT turbo to top pipe :?
I rather replace all or not at all. Won't look right with 1 standard as the rest in silicone.
paul2012
Postby jasonescortcozzie » Wed Aug 13, 2014 6:31 am
[url]http://m.ebay.co.uk/itm/281055296538 url]. Which ones are you missing from this Paul?
jasonescortcozzie
Postby paul2012 » Wed Aug 13, 2014 11:10 pm
jasonescortcozzie wrote:[url]http://m.ebay.co.uk/itm/281055296538 url]. Which ones are you missing from this Paul?
It's this hose from turbo to intercooler top pipe - arrow points to it in pic below.
paul2012
Postby paul2012 » Wed Aug 13, 2014 11:32 pm
Update from DVLA.
They have amended engine number & weight & should receive new V5 shortly.
Unfortunately they can't change Taxation class :? See below.....
paul2012
Postby jasonescortcozzie » Thu Aug 14, 2014 12:49 am
well that sucks Paul typical government clap trap though!
as for your hoses you can try this site if you measure your pipe up they should have something to match up http://www.viperperformance.co.uk/subcats.php?xctId=36 or email dan@samcosport.com and see if he can help you out.
jasonescortcozzie
Postby jasonescortcozzie » Thu Aug 14, 2014 1:11 am
you would think a DVLA employee would be able to spell registration though :lol:
jasonescortcozzie
Postby paul2012 » Thu Aug 14, 2014 2:36 am
jasonescortcozzie wrote:well that sucks Paul typical government clap trap though!
Thanks I will give them a try.
I noticed when removing O/S driveshaft, mine has started to split right at the bottom on the bend. So it needs to be replaced.
jasonescortcozzie wrote:you would think a DVLA employee would be able to spell registration though :lol:
I did notice that :wink:
They jump on people for removing CAT's & DPF's& is illegal to use a vehicle on the road that has had them removed - also an automatic MOT refusal if removed where one was fitted as standard.
But there no incentive for vehicles that have been adapted/modified to meet lower emission standards. (unless you live in London - LEZ compliant)
paul2012
