loot34 wrote:Pic isn't great
The copper C clip? You remove the centre bar then push the hub inwards to clear the groove that the clip is in and it should just slip off, there is a tsb for them being too loose(endfloat)
How is yours stuck?
bambi mk 1 wrote:You are allowed 1.8 mm endfloat.If you remove the bolt and lock tab on the bearing cap and tippex the ring nut inside the cap and back it off a few turns the clip will come out.I would doubt is the wheel bearing is causing the rumble.There should be a modification cage between the planetry gears also.
rogerw wrote:bambi mk 1 wrote:You are allowed 1.8 mm endfloat.If you remove the bolt and lock tab on the bearing cap and tippex the ring nut inside the cap and back it off a few turns the clip will come out.I would doubt is the wheel bearing is causing the rumble.There should be a modification cage between the planetry gears also.
Ok so slaken off bearing nut too. Oil in diff is cleanish, i was hoping wheel bearing at fault.
