VAG 1.9 TDi into a RWD transit
Re: VAG 1.9 TDi into a RWD transit
Postby Luke » Sun Sep 21, 2014 11:16 pm
andypdq wrote:Could run into problems as far as oil pick up and may have to build custom sump, and check out oil drain pathways for return back to the sump, to avoid oil pooling in unwanted places in the top of the engine, if it's stood upright. :idea:
yes i think the best position would be MT75 as it is in the transit and TDi as it is in the passat - in the passat its cranked over to the right (drivers side) as far as i know - and from what i gather 20degrees although it is the wrong way for me i think it'd be ok space wise :)
Postby Luke » Wed Sep 24, 2014 10:34 pm
another potential donor here :arrow:http://www.ebay.co.uk/itm/VW-Passat-TDI ... TQ:GB:1123
bit concerned over the oil in water thing :? is that an issue on these engines :?:
tempted to get it if it goes for £200 - (cant be worth much more with it having no 4th gear) at least i'll have an engine to play with :mrgreen:
Postby dieselhead123 » Thu Sep 25, 2014 7:57 am
Luke wrote:another potential donor here :arrow:http://www.ebay.co.uk/itm/VW-Passat-TDI ... TQ:GB:1123
Never known a VAG to do a head gasket mate, so likely just the oil cooler as the seller says.
Worth replacing if you do get it, lower oil temp will increase turbo life expectancy.
Postby Luke » Thu Sep 25, 2014 12:43 pm
slight update - apparantly the 2.0 crafter gearbox will fit :idea:
unfortunatly they are expensive £450 for a damaged one here :( http://www.vanservices.co.uk/the-shop/s ... -2012-core
Postby andypdq » Sat Sep 27, 2014 9:09 pm
Standard electronic AFN motor, 145 Lb/ft torque, MTDI, 195 @2400 RPM, Works out at 90 BHP @ 2400 RPM, if their dyno is accurate , so much for electronics. :idea:
https://www.youtube.com/watch?v=AtY-K0e1NI0
The first Mk 6 mechanical TDDI, giving electronics the finger, since April 2013
Perfection is reached, not when there's nothing left to add, but when there's nothing left to remove.
YouTube https://www.youtube.com/channel/UCNypVH ... dKUN5eJDyQ
andypdq
Postby Luke » Sat Dec 27, 2014 4:22 pm
well slight update on this i have this morning purchased a passat :D i was after an AFN 110ps one but the one ive bought i'm not sure :? i'll post some pics but in the photos it looked like it had silver TDI badges but close up you can see the DI was once red - and driving it back it pulls like a train :mrgreen: so i'm not sure if i've slipped up and bought a 130ps one :roll:
it was 1st reg on 31-5-2000
on the plus side it only cost me £265 and i've just put £10 diesel in and its drove back from birmingham 8)
Postby Luke » Sat Dec 27, 2014 4:24 pm
this was it (the winning bidder of this listing didnt turn up)http://www.ebay.co.uk/itm/291330220361? ... EBIDX%3AIT
click here for the image of the badge :arrow: http://i.ebayimg.com/00/s/MTIwMFgxNjAw/ ... h/$_57.JPG
Postby karl » Sat Dec 27, 2014 5:11 pm
so you bought ,drove back on a tenner from birmingham ? that good , i must say these are bulit prove and do thousands of miles even not being serviced good buy 8) we/i have a one with 200,000 plus on it and starts first turn on the key everytime 8) its for sale £500.00 new cam belt fulle service and 2 brand new front tyre :D it was going to ireland but thing changed :D
karl
Tranny Lover!!!
Postby bambi mk 1 » Sat Dec 27, 2014 5:50 pm
Pull up the boot floor mat and there should be a square sticker with the engine code :) on the floor
bambi mk 1
Postby Luke » Sat Dec 27, 2014 11:26 pm
karl mcghee wrote:so you bought ,drove back on a tenner from birmingham ?
we did indeed :mrgreen: 150k on this one - once its in my van i cant see it ever reaching 200k as its only going to be used as a camper :D
Postby Luke » Sat Dec 27, 2014 11:27 pm
bambi mk 1 wrote:Pull up the boot floor mat and there should be a square sticker with the engine code :) on the floor
nice one cheers i'll check tomorrow :D
Postby Luke » Sun Dec 28, 2014 1:12 pm
checked the plate and it's an ATJ engine :|
which looked up is an 85 kilowatts (116 PS; 114 bhp) @ 4,000 rpm; 310 newton metres (229 lbf·ft) @ 1,900 rpm
it does go well for a 114bhp :D
have i slipped up with this engine? is it complicated electronically? should i get an AFN one or do the conversion with this one?
Postby andypdq » Fri Jan 02, 2015 9:19 am
ATJ has the later "Pumpe Duse" unit injection system, they are pretty reliable but more complex than the earlier engines.
http://www.myarchive.us/richc/VW_TDI_with_PumpeDuse.pdf
You would be advised to peruse the VW forums for transplant info, but you will have to figure out the electronics, immobiliser, dashboard etc, no mechanical option on this one.
andypdq
Postby Luke » Fri Jan 02, 2015 8:15 pm
cheers Andy - that manual is spot on 8)
what do you think go for it with this one or flog it on and keep looking for an earlier AFN one :?: i'm keen to start it with this as it cost so little :lol: i'm thinking if i start the conversion with this i can always convert to AFN half way through all the mounts etc. will be the same :idea: and at least getting it physically mounted would be a big step :D
Postby andypdq » Mon Jan 05, 2015 2:04 pm
I suppose it's down to personal choice, I'd MTDI an AFN, because it's much more simple and easier to install, in a transplant situation, there's much less wiring for the installation, and much less to go wrong afterwards. If you're happy with the extra complication of the electronic systems, complete with a barrow load of wiring, then go for it, I'd wager it'd be more reliable than if you were to fit a Mk 6/7 engine. :lol:
I'd bet I'm one of the cheapest members on the forum, (ask Tim :lol: ) I don't give a toss about bells and whistles, I want to spend as little as possible, and still get reliable motoring with reasonable performance/economy, without getting any nasty, expensive surprises. Old VAG cars, with the 1.9 TDI, Audi 80, VW Passat, have served me well over the last 10+ years, 20,000 miles per year, no breakdowns due to engine management, or mechanical problems, with fantastic performance and economy, for what they are ( they don't seem prone to rust either ) with just regular servicing and the odd ball joint etc. I see little prospect of me MTDIing them or changing brands in the near future. :wink:
andypdq
