Transforming side loading door!
Postby screechowl » Sat Sep 27, 2014 1:45 pm
Has anyone ever replaced the side loading door of a panel van (Mark 5) with a hinged, caravan type door???
screechowl
Re: Transforming side loading door!
Postby captain hook » Sat Sep 27, 2014 10:07 pm
Only a midget I would think :roll: :lol: :lol:
captain hook
Postby redsquirrel » Sat Sep 27, 2014 10:29 pm
I hadn't thought of that I have replaced mine with a sliding door with a window already fitted. What type of door are you thinking of fitting?
Mk3 LWB 120, 2.0 litre convered to lpg/petrol; MK5 Travelhome 1989 reg.
MK5 LWB 190 2.5 D 1998 mid roof camper / welfare work transport.
Mk5 Hi Cube lwb 2.5 TD 1999 reg. (Converting into a camper).
redsquirrel
Postby MinorMatt » Sun Sep 28, 2014 10:20 am
BillyBoy turned his SLD in to a hinged door on his county camper conversion
Postby screechowl » Tue Sep 30, 2014 12:47 am
It was just an idea cos I hate the sliding door & I could put more fittings across the door space if it was like a caravan type door with a hinge. You can't put anything in the space with a SLD cos you have to pull the bloody thing to the side every time :evil: I'll try find Billy Boy's
screechowl
Postby dumper » Wed Oct 01, 2014 4:44 am
I think some police spec vans had hinged type sld doors
Postby captain hook » Wed Oct 01, 2014 7:30 am
dumper wrote:I think some police spec vans had hinged type sld doors
Yes...Mine did :wink:
captain hook
Postby screechowl » Wed Oct 01, 2014 6:43 pm
Right....so if I could get hold of a hinged sld off a police spec van I'd be set up :D
screechowl
Postby captain hook » Wed Oct 01, 2014 11:32 pm
screechowl wrote:Right....so if I could get hold of a hinged sld off a police spec van I'd be set up :D
No....The door is the same 8)
You need to re-enforce the B pillar and hinge the door from it....
Sorry if I'm being thick but....Why bother :?: :?:
captain hook
Postby ake » Fri Oct 03, 2014 7:13 am
All new van conversion campers still have the sliding side door, but the internal fittings extend half way across the opening, usually housing gas bottle etc.
I really can't understand why you would want to change it.
It's like having your patio doors removed and a solid wall, with a solid door put in its place!
Postby screechowl » Fri Oct 03, 2014 3:34 pm
ake wrote:All new van conversion campers still have the sliding side door, but the internal fittings extend half way across the opening, usually housing gas bottle etc.
Because you can't have any units in the way of the opening cos you need the whole space to swing the door along to open it. can't stand the din of the sld anyway. when you wake up everyone knows you're up when they here your sld! With a hinged door you don't have to stretch right across the space to open it so you could let a unit come half way across the opening space, as hooky explained & as Billyboy has done. He's emailed me picks of it. I understand now, it's the same door but with a hinge :wink:
screechowl
Postby ake » Fri Oct 03, 2014 6:19 pm
Factory 17 seat minibuses have stops on the door so the it only opens half way. Would that not do?
Postby screechowl » Fri Oct 03, 2014 7:34 pm
ake wrote:Factory 17 seat minibuses have stops on the door so the it only opens half way. Would that not do?
Nah, think I'll just get an ambulance or horse box instead :idea:
screechowl
Postby ake » Sat Oct 04, 2014 8:58 am
Most ambulances built since the 90s have a sliding side loading door!
Most of them use the Transit fittings, even those built on Merc/VW chassis
