No Pictures - available correct size pcd Transit alloys
Re: Pictures of all available correct size pcd Transit alloy
Postby wojciech » Tue Sep 09, 2014 11:18 am
Final conclusion from viewtopic.php?f=5&t=149931&start=15
AndyG wrote:
limitedblack wrote:
ake wrote:So to sum up,
Transit alloys fit Transits
P100 steel wheels(will NOT fit any MK7!)
fit, but they are the wrong offset,The stud size is different and not hub-centric and there weren't ever any alloys
Tourneos are posh Transits built from Transit bits, including the wheels, so we can say that Transit wheels will fitBut only from MK6 to MK7!
Tats wheels are rarer than Transit wheels, awful and only fit up to MK 5
Perhaps seven million is a slight exaggeration, but I bet it gets asked once a week at least!
I suggest you save this quote ready for the next time someone asks, then your first answer will be correct ;)
wojciech
Postby wojciech » Mon Sep 15, 2014 7:32 pm
Producer: MAK (Italy) - http://www.makwheels.it,
Model: ARIA,
Size:6,5Jx16 ET 60 mm and 7,5Jx18, ET 48 mm,
PCD: 5 x 160 mm
Finishing: Silver, Gun Metallic Mirror Face and Ice Black
wojciech
Postby wojciech » Mon Sep 15, 2014 7:51 pm
Popular alloys Alessio TOP, known in two sizes 6.5Jx15" and 6,5Jx16", ET 50 mm, now are available as Borbet/CW model CWF in two finishing: Crystal Silver and Black Glossy, but only 6,5Jx16" ET 60 mm.
TÜV certificate
wojciech
Postby wojciech » Mon Sep 15, 2014 8:34 pm
Producer: BROCK / RC (Germany) - http://www.rcdesign.de,
Model RC25,
Size: 6,5Jx16, ET 55 mm and 7,5Jx18, ET 50 mm, PCD 5x160 mm,
Finishing: Kristallsilber (KS) oraz Schwarz Klar Matt (SKM)
TÜV certificate
wojciech
Postby wojciech » Tue Sep 16, 2014 7:04 pm
Brand: : Wolfrace, model : Assassin TRS, size 8Jx18, PCD 5x160mm, offset 50 mm, finishing Black with Polished Face
http://www.wolfrace.com/blog/?p=792
wojciech
Postby wojciech » Tue Sep 16, 2014 7:19 pm
wojciech wrote:Manufacturer: Calibre
Model: Odyssey
Stud: 5x160 mm
ET: 48 mm
Painting: Matt Black
http://www.ebay.co.uk/itm/18-FORD-TRANS ... #vi-ilComp
Uploaded with ImageShack.us
Now available with finishing Gun Metal and Silver
wojciech
Postby wojciech » Fri Oct 10, 2014 7:06 pm
wojciech wrote:Now available with finishing Gun Metal and Silver
and Black & Polished
Picture from viewtopic.php?f=65&t=151125
wojciech
Postby wojciech » Mon Nov 10, 2014 12:47 pm
GMP Italia Job Black Polished are now available in three finishing: Silver, Black Polished and Matt Black
They are looking exactly as Alessio TOP or Borbet/CW model CWF (two sizes 6.5Jx15" and 6,5Jx16", ET 50 mm).
wojciech
Postby bigjohnthomas » Mon Nov 10, 2014 1:10 pm
wojciech wrote:Popular alloys Alessio TOP, known in two sizes 6.5Jx15" and 6,5Jx16", ET 50 mm, now are available as Borbet/CW model CWF in two finishing: Crystal Silver and Black Glossy, but only 6,5Jx16" ET 60 mm.
TÜV certificate
also available in bjt amphrashite :P
bigjohnthomas
Postby Rescue_marshal » Wed Dec 03, 2014 10:35 pm
Can't stop dribbling at most of these alloys!!! Lot more work to do to mine before that stage though. 3 small areas of surface rust for a start :-/ won't stop me putting some decals on first though ;-)
Transit hi top 350 Lwb TD 2402
Rescue_marshal
Postby Rescue_marshal » Wed Dec 10, 2014 9:53 pm
Am I right in thinking my Lwb wheels are 17inch??? Measured rim to rim, standard steels fitted at the mo. Cheers lee
Rescue_marshal
Postby wojciech » Fri Jan 30, 2015 9:26 pm
SuperMetal Hammer Alloys
Three finishing: Silver or Black or Gunmetal+Polished
size 6.5 x 16", 5x160mm, ET60, CB 65.1mm
Last picture with Custom looks for Photoshop - because of very small PCD (it isn't 5x160)
http://www.tyresave.co.uk/alloytransit.html
wojciech
Postby wojciech » Wed Mar 18, 2015 9:07 am
Model: Z1108, size 6,5 x 15", ET 50 mm, 5 x 160 mm, CB 65,1 mm, color: silver.
http://felgi1.com/?utm_source=sender&utm_medium=email&utm_campaign=Lenkijos%2Brinkai%2B2015%2F03%2F17
wojciech
Postby wojciech » Sat Mar 21, 2015 6:30 pm
Producer: CMS, model CV2/LK5, size 6,5 x 16", PCD 5 x 160 mm, ET 60 mm, CB 65,1 mm. Loading 1215 kg
Finishing: Racing silver and Diamond matt black/polished
On picture is shown model CV2/LK6 with PCD 6 x 130 mm, correct picture is inaccessible... :cry:
http://cmswheels.de/download/fdc00460bd34fac5879577a2b64aef2f.pdf
wojciech
Postby wojciech » Sat Mar 21, 2015 7:06 pm
Brand: Advanti
Style: Delta
ET: 50mm
PCD: 5x160 mm
Colour: Gunmetal Machine Face
wojciech
